The Accel Calibration doesn’t work for v2.0.13. It jumps the last(place vehicle on it’s back) step causing the calibration to fail. What version is known to work?
[quote=“kahoona”]Hi,
The Accel Calibration doesn’t work for v2.0.13. It jumps the last(place vehicle on it’s back) step causing the calibration to fail. What version is known to work?[/quote]
O.K got it working after 10+ attempts. Don’t know why. It’s definitely some bug there.
Great, I just tested this and was working for me.
You need to keep the copter very still for it to work.
[quote=“billbonney”]Great, I just tested this and was working for me.
You need to keep the copter very still for it to work.[/quote]
I had it mounted with tape on my pre assemble board so it was completely still between the different steps.
The “press to start calibration” button didn’t change even do I pressed it. But the countdown for that step started to count down. When I came to the last step it just jumped that step and I had a mix of text, “place vehicle on its back” togheter with “calibration failed” and the found readings. So there is some bug in there. I pulled the usb cable three times and on the third time it worked. Between that I tried several times and it didn’t work.
