I am new in this community. Yesterday I bought a cube black and install 4.0.1 firmware. I made accel setting but I think something wrong. I lie the cube left, mission planer and QGC shows lie right. I lie the cube right, mission planer and QGC shows lie left. Is it normal or How can I fix this?
Welcome ,
After starting Accel calibration. first place the vehicle perfectly level & click any key. Then do what GCS asks. After all is done, point the vehicle’s front at the computer screen & roll it right, the HUD will tilt left & vice versa.
I do what you say and nothing change. I watched alot of videos about accel calibration. Every video say same thing. I did it meticulously as a whole. I used water gauge. Nothing change. Even I tried making accel calibration wrong (QGC say lean left I lean right) but nothing change
Yes I complete the calibration process three times, two different computer and three diffrent firmware. (ardusub, ardurover and arducopter). 2 week ago I completed the calibration process with pixhawk 2.4.8 clone. There were no problem. I tried to re-calibrate the 2.4.8 then also its wrong
Hey don’t feel sorry.
If I understand it correctly, If you tilt the FC RIGHT, the HUD is tilting LEFT. Is this your problem ?.
If not, describe your problem or Make a small video of the problem, upload it somewhere & post the link here. Some experts will help.
At first I thought I had the same problem, But then I realized that in the HUD, the Ground(green) is tilting the opposite of the craft. Which is correct behavior.
In the HUD, the craft stays level on screen, and the ground/air rotates the opposite direction you tilt the pixhawk.
The map will only show current position when you have GPS lock or are using a flight simulator
Remember how artificial horizons work: when the aircraft tilts to the right, the horizon tilts to the left. (Just tilt your head and you’ll see what I mean). This is normal! Please don’t tell us it’s reversed.
