I use pixhawk, AC3.2.1 firmware. When only the aircraft is rotated in the YAW direction, the angle of the PITCH and ROLL of the aircraft will also be affected, causing the aircraft to drift heavily in the PITCH and ROLL directions. This is because the DCM itself. Question?
