Doolly
(Doolly)
1
Hi I’m using orange TX & RX and they provide multi binding
however I’m concerned about ‘multi binding’ is this means it can store binding data and communicate one on one?
or does it work simultaneously?
I tested them two copters got armed simultaneously
but if I send throttle,roll,pitch command they work crazy, they have same gains and same hardware
should I not bind multi receiver at same time?
CLabeck
(Christian Labeck)
2
what are you trying to achieve with “Multi-Binding”?
Chris
Doolly
(Doolly)
3
I’m not trying to achieve something with Multi-Binding
I’m trying swarm flight with ROS and had RC noise issue
and one of the reason I’m considering is multi-binding issue
because I used two copters binded in one reciever
