I set up in accordance to https://ardupilot.org/rover/docs/common-non-gps-to-gps.html. I use GPS as the main source of pos estimation , and extNav (cartographer positioning in the companion computer TX2) as the second data source, but when I did the source switching experiment, EKF was red. When switching to extNAv as the data source, I set EKF origin, but nothing is reflected, and there is no expected car. Is there something I haven’t configured?Any suggestions will be appreciated. This picture shows the print message of my flight controller in the mission planner .
Basically you just need to set VISO_TYPE = 1 (MAVlink) or 2 (T265)… if Cartographer provides attitude and velocity then I think “2” should work. If it only provides position and/or velocity then use “1”.
Sorry to bother you again, I tried to set VISO_TYPE to 1 and 2 respectively, but the results of both are EKF is red, indicating that there is a problem with EKF (but EKF is white when I do non-GPS experiments with 4.0), there are vision_pose_Estimation and / cmd_vel data, why is this? Thank you.
Hi @rmackay9,
You are right! After changing VISO_TYPE, the ardupilot should be rebooted. Now, everything goes well, I will try the automatic switching function next time,thank you very much
hi randy i read GPS / Non-GPS Transitions — Copter documentation and watch your video https://www.youtube.com/watch?v=3LUr0sySbgM about this topic however i want to now for define external nav source for pixhawk board to navigate without gps, in copter firmware 4.4, does this firmware have AP_NavEKF_Source.h ? or i have to build new firmware manually which have this .h file.thank you
