About cruise_speed and cruise_throttle
Dear all,
After the topic for John Easton’s wobbly navigation (John Easton's boat navigation) which was initially raised on facebook, I try to set the cruise_speed and cruise_throttle as negative value. I discover severe oscillation on the rover or even can not move after armed.
Here is the figure I plot in meters:
This is the lattitude measurement.
This is the longtitude measurement.
I think the cruise_speed and cruise_throttle should not be set as negative and there is some rational range.
Am I right?
Thank you very much.
Zhijian,
Negative is not a good choice for these parameters! :-). We can add a checks to stop users from adding negative value but it’s already in the parameter description info which should be visible in the ground stations.
Thank you very much, rmackay.
But I double the source code somehow may exist the problem about cruise_speed and cruise_throttle. Let us look at the code below:
APMrover2/mode.cpp:
// estimate maximum vehicle speed (in m/s)
// cruise_speed is in m/s, cruise_throttle should be in the range -1 to +1
float Mode::calc_speed_max(float cruise_speed, float cruise_throttle) const
float speed_max;
// sanity checks
if (cruise_throttle > 1.0f || cruise_throttle < 0.05f) {
speed_max = cruise_speed;
} else {
// project vehicle’s maximum speed
speed_max = (1.0f / cruise_throttle) * cruise_speed;
// constrain to 30m/s (108km/h) and return
return constrain_float(speed_max, 0.0f, 30.0f);
I draw this code in figure:
If the cruise_speed is near the value 0.05 (for example 0.51), the speed_max may be 20 times of the cruise_speed. I think this is not rational, right?
And the negative value is not contraint here, which may also lead to abnormal behavior.
Am I right?
Thanks.
Sorry, type error. I doubt the source code somehow may exist the problem
Sounds like you worked it out but in any case, I think if the cruise-throttle were way down at 0.051 (i.e. 5.1%) then it’s reasonable that the vehicle’s top speed could be 20x the cruise-speed. That would generally be a poor choice of cruise-throttle and cruise-speed by the user but it’s a reasonable result still.
Thanks for investigating
