I have been running into an issue that I think can be replicated (have done so on multiple computers, multiple versions .72 and .73, and multiple different links, etc).
Here is a video showing the process I am doing to replicate the freeze. Here is the MP console output when the error first starts when switching windows (for .72 and .73). In summary both versions throw null exceptions. Here is the waypoint file in use… don’t think this should affect it though.
ERROR MissionPlanner.GCSViews.FlightData - System.NullReferenceException: Object reference not set to an instance of an object.
at MissionPlanner.GCSViews.FlightData.<mainloop>d__167.MoveNext()
The issue seems to not occur in the first place by writing the waypoints after reading, or can be fixed by writing the waypoints from the plan page.
It seems that this issue seems to happen if you have not written any waypoints to the AC and only read waypoints during a telemetry session.
Yes it seems it is replicable, and looks like that cause is the takeoff command at the start.
Need a deeper check…
Update: OK, the problem is that if the copter home is not set (Set Home Here, or Arm) and the first item is a takeoff then updating the distance bar is failing, because it compare waypoint distances to the first item (which normally the home position, but if there is no home, it is the takeoff command which does not have position). I have some ideas how to fix it, but ultimately the decision is up to @Michael_Oborne
in the new version there was a separation of planned home vs actual home. i added some logic to use planned home if actual home doesn’t exist, this was because there could have been a display issue if you use some of the set home here from flightdata
