I have a question wrt odd flight behaviour on a 7’ quad after autotune.
I am in the process of tuning a 7 inch recon - 7 quad, which is going very well so far.
Mostly I am following the tuning guide in the doc section and the 7’ standard build thread by @andyp1per which is an excellent thread to follow, many thanks for the guidance!
I have progressed to the point where I ran autotune on yaw, then autotune on all 3 axes.
Quad seems to fly nicely on the basis of ‘feel’ so that looked good.
Next I wanted to check if RTL is working, and it is, but flight behaviour was strange.
The quad flies to the home point, but while doing so pitches quite suddenly down, then recovers.
It repeats this several times on the way back to home, then lands.
So in essence the test was succesful, but it is quite worrying to watch.
Pitch down angles are in order of 60 degs…
I tried another flight, flying forward / back, port / starboard, up / down with only stick commands.
In flight modes loiter, alth and stab. The issue seems to also occur in all these modes, mostly while flying backward and releasing stick, And when flying ‘down’. But there are other occasions where the pitch down does not happen…
So I looked at the logs, it seems to me that when the pitch down occurs, the quad is not following the commanded pitch signal well.
If the commanded pitch is increasing, the quad pitches down. I checked signs in the tuning parameters and they look ok to me…
So now I am a bit puzzled, and would like to request advice.
Is this a form of ‘rotorwash’ instability? (that was next on Andy’s test).
Are the autotuned pid values somehow unreasonable?
Did I configure something wrong?
I have quite a bit experience with rc and uav helicopters, but I am new to arducopter, so it’s quite possible I didn’t get some obvious thing right.
All help very much appreciated!
Boris
parameter file included using “upload” button
2023_03_29_before_rtl_propwash_vibration_test.param (19.7 KB)
log file included using wetransfer link
