Thanks! Now is cristal clear that we should use BEC.
So, I bought the BEC and wired, but the servo is not working (I checked and Mission planner is showing the changes in Output 7) I show this picture that shows the wiring:
Then, I read here that I should also wire the negative of the BEC to the negative (DC return) of Pixhawk:
(By the way, I’m connecting the BEC to the balance cable of one batery, because I have two 6S bateries in serial)
Then, I made this wiring and some smoke started to came out from the servo
Should I made this wiring between negative of BEC and negative of Out Bus of pixhawk?
Why the servo is not working?
Thank you so much, I appreciate your feedback.
Regards.
