50amp Speedybee ESC With APM 2.8
I wanted to use the 50amp Speedybee ESC with the Apm 2.8. Is it possible?
Possible but not recommended:
Even if it is not recommended, can someone tell me how to use it.
That is the problem, almost no one uses that, so almost no one can answer you. But you can search this forum section and in the documentation archives.
Not even a VAGUE idea? Also I can’t buy any new boards since over here in India they are really expensive. A Speedybee F405 V3 Stack is around $75.
Use any ESC that accepts PWM, which is practically all of them. But I would throw that APM in the trash.
its ÂŁ15 for cheapest board that can run latest ardupilot. There is no good reason to use a APM.
https://www.aliexpress.com/item/1005006024284325.html
Like any other FC, plus you have to hope that it’s built to the original specs (whatever they are) and that the components are working. :wink:
You really don’t want to do that unless you really like your 8 bit controllers and want to spend way more time troubleshooting on your own than it is worth.
Get any supported F405 based flight controller with baro and you will be good.
Oh sure, I wouldn’t do it, and he shouldn’t do it. But he seems hell-bent on using it…
