I’m looking to build a 4WD rover; I notice in the Ardurover software there’s only modes for steering/throttle and skid-steer. Can skid-steer do what I want? But 4WD?
What board should I get? Everyone seems to run the Pixhawk; but I eventually want it to talk to a Jetson Nano to do some object recognition. I see the NAVIO2+Raspberry Pi but not sure if that’s up to the task.
I will also need the frame, battery, PDB, GPS, receiver/transmitter.
Any advice would be greatly appreciated. Thank you!
Those motors and ESC’s will work fine. I have a 4wd Crawler with a PixRacer. but just about any Flight Controller that supports ArduRover will do. The demands for a rover are low. All you need for a companion computer is a serial port.
For a chassis I just converted a Redcat Crawler which runs great.
If you want 4wd with Ackerman steering then your only option would be to assign the front wheels to the same throttle output as the rear. If you want 4x independently driven wheels then you are out of luck. We have a similar setup but with 2x steering motors and I had to implement our own solution to drive all 6 motors.
Thank you everyone for the responses! I have decided to go with 2WD instead (skid-steer, 2 drive wheels and a castor). Maybe for the next iteration I will do 4WD with the front wheels as same output as the rear.
Got an RC system? You will want one for setup and calibration. If you are thinking, as many do, that you will just fly/drive this vehicle with a mobile device you will still want an RC system.
