I’m have many messages from CRSF - CRSF: RF mode 2, rate xxx, and some time i’m see FS (at 2m ).
And i’m see GPS lagging too.
FC: mamba f405 mk2
CRSF to serial1 (dma enabled and recompiled)
GPS to serial6
ESC tele to serial3
Can you post the hwdef you used - just because you enabled DMA doesn’t mean that it actually worked.
Are you using ELRS or vanilla TBS CRSF?
I’m only delete NODMA from rx and tx in hwdef for serial1
Its working because i’m have crsf rate which using with DMA enabled ports.
Using MicroTX v2 CRSF no elrs
Strange - looks like on that board it works ok.
I’m see from MP messages -
01.08.2021 12:00:22 : CRSF: RF mode 2, rate is 156Hz 01.08.2021 12:00:17 : CRSF: RF mode 1, rate is 157Hz 01.08.2021 12:00:09 : CRSF: RF mode 2, rate is 154Hz 01.08.2021 12:00:05 : CRSF: RF mode 1, rate is 157Hz 01.08.2021 11:58:55 : CRSF: RF mode 2, rate is 156Hz 01.08.2021 11:58:50 : CRSF: RF mode 1, rate is 157Hz 01.08.2021 11:58:43 : CRSF: RF mode 2, rate is 155Hz 01.08.2021 11:58:38 : CRSF: RF mode 1, rate is 154Hz
This CRSF or AP problems?
This is a CRSF issue - the mode switching can happen if the signal is flaky
Yes - i’m disable mavlink in rx nano and this messages go out…
