P60 motor
Hobbywing xRotor 60a esc
22 inch prop
Cube Orange
7kg take off weight
We have a sudden crash and we dont know why. Anyone can help us?
Normal flight, stable flight, loiter mode, no bad movements, no message warnings. suddenly fell off.
See the graph I included. All goes well, then motor2 output went max, while opposite motor1 went to zero to compensate. This is a typical motor loss scenarioβ¦ the output set to max because the flight controller sense loss of thrust on that motorβ¦
I recommend ESCs with telemetry to everyone now for this exact reason, without telemetry there is really no way of being 100% sure, I have changed whole arms out of customer machines because it was cheaper than risking another failure even when everything tests fine and itβs possible it was a loose propeller.
If your propellers have a single nut and are all standard right hand thread then itβs possible motor 2s propeller could have came loose. but since your running 22 inch props i doubt thats the case.
No, we use the T-motor folding propeller MF2211L, attached with 2 M3bolts.
the post crash inspection, the motor 2 have one blade of the propeller broken at the root, but itsnt possible to know if the break came from the crash of before crash
ESC is the most lightly culprit, replace it and check all the wiring, make sure its secure, and your signal wire is not wrapped around your motor wires or anything funky like that.
you will have to check and possibly replace all your motors, if its landed inverted its probably bent them, make sure there are no vibrations or loose magnets.
