Log File D:/…/X8+/Logs/2016-06-05 09-40-19.log
Size (kb) 11438.015625
No of lines 152019
Duration 0:10:43
Vehicletype ArduCopter
Firmware Version V3.2.1
Firmware Hash 36b405fb
Hardware Type
Free Mem 0
Skipped Lines 0
Test: Autotune = NA -
Test: Balance/Twist = NA -
Test: Brownout = GOOD -
Test: Compass = GOOD - mag_field interference within limits (14.02%)
Test: Dupe Log Data = GOOD -
Test: Empty = GOOD -
Test: Event/Failsafe = FAIL - ERR found: FS_BATT (This is OK and expected)
Test: GPS = GOOD -
Test: IMU Mismatch = WARN - Check vibration or accelerometer calibration. (Mismatch: 1.25, WARN: 0.75, FAIL: 1.50) (This one worries me a lot! Is this just because X8+ flew with only 7 props on?)
Test: Parameters = GOOD -
Test: PM = NA -
Test: Pitch/Roll = NA -
Test: Thrust = NA -
Test: VCC = GOOD -
Is there anything else, apart of putting the missing prop back, I should do to get the IMU Mismatch back to GOOD?
The X8+'s 8-10 minutes auto mission logs analysis show everything as GOOD, but always indicate IMU Mismatch.
I’m afraid to mess with the accelerometer calibration. I sure it will ask to also calibrate the compass. And I had a hard time calibrating the compass on Iris+ very recently, and it crashed due to accelerometer issue.
Telemetry logs (also known as “tlogs”) are recorded by the Mission Planner (or other ground station) when you connect ArduPilot to your computer via a telemetry link.
I am connecting to X8+ using Tower to do an automission. I can find NO telemetry logs in there. Do I have to use PC-based Ground Control Station to have the Telemetry Logs?
Tower has tlogs too. They are actually in the Services app and not Tower. There hard to find but should be in the Droid planner services folder. They should be in “Android/data/org.droidplanner.services.android/files/tlogs/org.droidplanner.android/” folder.
