Greetings,
I purchased the 3DR Video/OSD kit a few months ago. I’ve had a few successful flights with it connected to the Pixhawk. It is wired just like in the instructions:
3drobotics.com/wp-content/upload … nual-D.pdf
Yesterday, I went to test my systems, and noticed it was not working.
After a couple of minutes (which probably involved disconnecting and reconnecting the battery), I got a camera image up on my monitor, but no MinimOSD overlay. It went away after about 45 seconds. Since that time, nothing.
So far I’ve tested the following:
I connected camera directly to power and my monitor. Camera, battery, and monitor all work.
I did a continuity check on the three leads from transmitter to MinimOSD board - all good.
I did a continuity check on the three leads from MinimOSD board to camera - all good
I checked voltage at the cable coming into the transmitter – 11.6 volts.
I checked the voltage at the cable coming into the MinimOSD – 11.2 volts
There is a single red light on the transmitter.
There is a single red light on the receiver.
When I power the Pixhawk, but not the video side, I get a solid red light, and a solid amber light on (what I believe to be) the digital side of the MinimOSD board. Once I plug in the battery to the VideoTX/MinimOSD/camera, I get an additional red light on (what I believe to be) the analog side of the MiniOSD board.
All of the channel selection switches are in the default position (all in one direction), as I have not removed the heat shrink. On the receiver, all the switches are UP. I’ve also tried with them all switched DOWN. No change in behavior.
I don’t see any damaged components on the MinimOSD or the transmitter.
If I had another transmitter, I’d swap it in to test, but I don’t. I’m not sure what else I can try. Any suggestions?
Thanks!
John
