Hello!
So, I’ve bought a telemetry module on “aliexpress”, 915mhz and I can’t connect on mission planner / apm2 software.
Please, have someone saw this problem?
If I connect by usb cable, all works perfectly (and all params are downloaded)
But with this telemetry module, no.
Previously, I’ll thanks for attention and help.
See this log on apm software.
[20171126 22:52:29.273 INFO ] - QGCCore::initialize()
[20171126 22:52:29.273 INFO ] - Current Build Info
[20171126 22:52:29.273 INFO ] - Git Hash: e2bcdb47229d9f33e5d5931a74958de5b35d432f
[20171126 22:52:29.273 INFO ] - Git Commit: 2.0.24
[20171126 22:52:29.273 INFO ] - APPLICATION_NAME: “APM Planner”
[20171126 22:52:29.273 INFO ] - APPLICATION_VERSION: “v2.0.24”
[20171126 22:52:29.273 INFO ] - APP_PLATFORM: win
[20171126 22:52:29.273 INFO ] - APP_TYPE: stable
[20171126 22:52:29.477 INFO ] - Start Link Manager
[20171126 22:52:29.477 DEBUG] - Create MAVLinkDecoder: MAVLinkDecoder(0x3a628c8)
[20171126 22:52:29.492 INFO ] - Start UAS Manager
[20171126 22:52:29.673 DEBUG] - Creating MainWindow
[20171126 22:52:29.814 INFO ] - Creating SubMainWindow: SubMainWindow(0x3572120)
[20171126 22:52:29.815 INFO ] - setting objectName: “VIEW_MISSION”
[20171126 22:52:29.861 INFO ] - Creating SubMainWindow: SubMainWindow(0x350db60)
[20171126 22:52:29.861 INFO ] - setting objectName: “VIEW_FLIGHT”
[20171126 22:52:29.895 INFO ] - Creating SubMainWindow: SubMainWindow(0x350f3a0)
[20171126 22:52:29.895 INFO ] - setting objectName: “VIEW_HARDWARE_CONFIG”
[20171126 22:52:30.245 DEBUG] - fillPortsInfo
[20171126 22:52:30.252 INFO ] - Inserting “COM4”
[20171126 22:52:30.253 INFO ] - Changed Link to: “COM4”
[20171126 22:52:30.258 INFO ] - Inserting “COM4”
[20171126 22:52:30.258 INFO ] - Changed Link to: “COM4”
[20171126 22:52:30.318 WARN ] - libpng warning: iCCP: known incorrect sRGB profile
[20171126 22:52:30.323 WARN ] - libpng warning: iCCP: known incorrect sRGB profile
[20171126 22:52:30.326 WARN ] - libpng warning: iCCP: known incorrect sRGB profile
[20171126 22:52:30.515 INFO ] - Creating SubMainWindow: SubMainWindow(0x614c5e0)
[20171126 22:52:30.515 INFO ] - setting objectName: “VIEW_SOFTWARE_CONFIG”
[20171126 22:52:30.533 DEBUG] - Disable Controls
[20171126 22:52:30.690 INFO ] - Creating SubMainWindow: SubMainWindow(0x614d560)
[20171126 22:52:30.690 INFO ] - setting objectName: “VIEW_ENGINEER”
[20171126 22:52:30.729 INFO ] - Creating SubMainWindow: SubMainWindow(0x87d79d0)
[20171126 22:52:30.729 INFO ] - setting objectName: “VIEW_SIMULATOR”
[20171126 22:52:30.781 DEBUG] - MODE: 0
[20171126 22:52:30.792 DEBUG] - “D|PREFLIGHT”
[20171126 22:52:30.794 DEBUG] - MODE: 80
[20171126 22:52:30.795 DEBUG] - “D|STABILIZED”
[20171126 22:52:30.796 DEBUG] - MODE: 64
[20171126 22:52:30.797 DEBUG] - “D|MANUAL”
[20171126 22:52:30.798 DEBUG] - MODE: 88
[20171126 22:52:30.799 DEBUG] - “D|VECTOR|STABILIZED”
[20171126 22:52:30.801 DEBUG] - MODE: 92
[20171126 22:52:30.801 DEBUG] - “D|AUTO|STABILIZED”
[20171126 22:52:30.804 DEBUG] - MODE: 66
[20171126 22:52:30.805 DEBUG] - “D|TEST”
[20171126 22:52:30.882 DEBUG] - QUrl(“file:///C:/Program Files (x86)/APMPlanner2/qml/PrimaryFlightDisplayQML.qml”)
[20171126 22:52:31.062 DEBUG] - QML Status: 1
[20171126 22:52:31.066 DEBUG] - QUrl(“file:///C:/Program Files (x86)/APMPlanner2/qml/PrimaryFlightDisplayQML.qml”)
[20171126 22:52:31.148 DEBUG] - QML Status: 1
[20171126 22:52:31.157 INFO ] - UASActionsWidget creating UASActionsWidget(0x612fa18)
[20171126 22:52:31.162 DEBUG] - QuickView: load settings
[20171126 22:52:31.165 DEBUG] - QuickView: loading key: “GCS Status.Altitude (GPS) (m)” type: “text”
[20171126 22:52:31.179 DEBUG] - QuickView: loading key: “GCS Status.Altitude (REL) (m)” type: “text”
[20171126 22:52:31.185 DEBUG] - QuickView: loading key: “GCS Status.Battery (%)” type: “text”
[20171126 22:52:31.188 DEBUG] - QuickView: loading key: “GCS Status.Climb (m/s)” type: “text”
[20171126 22:52:31.191 DEBUG] - QuickView: loading key: “GCS Status.Current (A)” type: “text”
[20171126 22:52:31.195 DEBUG] - QuickView: loading key: “GCS Status.GPS Fix ()” type: “text”
[20171126 22:52:31.200 DEBUG] - QuickView: loading key: “GCS Status.GPS HDOP (m)” type: “text”
[20171126 22:52:31.205 DEBUG] - QuickView: loading key: “GCS Status.GPS Sats ()” type: “text”
[20171126 22:52:31.209 DEBUG] - QuickView: loading key: “GCS Status.Pitch (deg)” type: “text”
[20171126 22:52:31.216 DEBUG] - QuickView: loading key: “GCS Status.Roll (deg)” type: “text”
[20171126 22:52:31.223 DEBUG] - QuickView: loading key: “GCS Status.Voltage (V)” type: “text”
[20171126 22:52:31.229 DEBUG] - QuickView: loading key: “GCS Status.Yaw (deg)” type: “text”
[20171126 22:52:31.241 DEBUG] - QuickView: load settings END
[20171126 22:52:31.311 DEBUG] - qmlBaseDir “C:/Program Files (x86)/APMPlanner2”
[20171126 22:52:31.312 DEBUG] - QUrl(“file:///C:/Program Files (x86)/APMPlanner2/qml/ApmToolBar.qml”)
[20171126 22:52:31.363 DEBUG] - APMToolBar: button label SELECTED
[20171126 22:52:31.391 DEBUG] - QML Status: 1
[20171126 22:52:31.396 DEBUG] - Setting for “USER_DONATED” : QVariant(QString, “false”)
[20171126 22:52:31.397 DEBUG] - Set Advanced Mode true USER_DONATED:false
[20171126 22:52:31.398 DEBUG] - Donate visible
[20171126 22:52:31.404 INFO ] - NETWORK_PROXY: Disabling System Network Proxies
[20171126 22:52:31.410 DEBUG] - Loading widget: “PRIMARY_FLIGHT_DISPLAY_QML_DOCKWIDGET”
[20171126 22:52:31.411 DEBUG] - Loading widget: “UAS_INFO_INFOVIEW_DOCKWIDGET”
[20171126 22:52:31.566 WARN ] - QObject::moveToThread: Current thread (0x614d840) is not the object’s thread (0x614b960).
Cannot move to target thread (0x1543b78)
[20171126 22:52:31.632 WARN ] - QSettings::endGroup: No matching beginGroup()
[20171126 22:52:31.641 DEBUG] - Create Serial Connection: SerialConnection(0x91224b0)
[20171126 22:52:31.641 INFO ] - “COM4” 57600
[20171126 22:52:31.782 DEBUG] - APMToolBar: new Serial Link Created 1
[20171126 22:52:31.782 DEBUG] - APMToolBar setConnection: false
[20171126 22:52:31.798 DEBUG] - APMToolBar: updateLinkDisplay “COM4” : “57600” connected: false
[20171126 22:52:31.798 INFO ] - UDP Created “UDP Link (port:14550)”
[20171126 22:52:31.798 INFO ] - UDPLink::UDP connect QHostAddress(QHostAddress::Any) : 14550
[20171126 22:52:31.851 DEBUG] - SCW: Link is disconnected
[20171126 22:52:31.851 DEBUG] - Baud rate: 57600 Expected: 3
[20171126 22:52:34.650 DEBUG] - APMToolBar: CONNECT SELECTED
[20171126 22:52:34.651 DEBUG] - APMToolBar: connectMAV QObject(0x0) with sLink 1
[20171126 22:52:34.652 DEBUG] - SerialConnection::connect()
[20171126 22:52:34.655 ERROR] - serial connection: error 0
[20171126 22:52:34.679 DEBUG] - APMToolBar setConnection: true
[20171126 22:52:34.680 DEBUG] - APM Tool BAR QML: connected
[20171126 22:52:34.683 DEBUG] - APMToolBar: updateLinkDisplay “COM4” : “57600” connected: true
[20171126 22:52:34.685 DEBUG] - APMToolBar: DISCONNECT unselected
[20171126 22:52:35.088 ERROR] - serial connection: error 11
[20171126 22:52:35.377 WARN ] - QObject::connect: No such signal SerialConnection::disconnected(QObject*)
[20171126 22:52:35.378 INFO ] - ArduPilotMegaMAV APM Connected
[20171126 22:52:35.382 DEBUG] - LinkManger::startLogging() “C:/Users/diogo.rocha/apmplanner2/tlogs/hexcopter//2017-11-26 22-52-35.tlog”
[20171126 22:52:35.383 DEBUG] - Start MAVLink logging “C:/Users/diogo.rocha/apmplanner2/tlogs/hexcopter//2017-11-26 22-52-35.tlog”
[20171126 22:52:35.496 DEBUG] - ATTEMPTING TO LOAD CSV
[20171126 22:52:35.499 DEBUG] - AUTOPILOT: “ARDUPILOTMEGA”
[20171126 22:52:35.501 DEBUG] - FILENAME: “C:/Program Files (x86)/APMPlanner2/files/ardupilotmega/parameter_tooltips/tooltips.txt”
[20171126 22:52:35.507 DEBUG] - src\uas\UAS.cc 2160 LOADING PARAM LIST
[20171126 22:52:35.531 DEBUG] - No default custom widgets for system “HEXAROTOR” autopilot “ARDUPILOTMEGA” found
[20171126 22:52:35.532 DEBUG] - Tried with path: “C:/Program Files (x86)/APMPlanner2/files/ardupilotmega/widgets/”
[20171126 22:52:35.535 DEBUG] - Loading widget: “PRIMARY_FLIGHT_DISPLAY_QML_DOCKWIDGET”
[20171126 22:52:35.536 DEBUG] - Loading widget: “UAS_INFO_INFOVIEW_DOCKWIDGET”
[20171126 22:52:35.553 DEBUG] - addUAS “MAV 001”
[20171126 22:52:35.555 INFO ] - QGCMapTool::activeUASSet
[20171126 22:52:35.557 INFO ] - QGCMapTool::activeUASSet
[20171126 22:52:35.560 DEBUG] - AHC: uasConnected()
[20171126 22:52:35.561 DEBUG] - toggleButtonsShown true
[20171126 22:52:35.563 DEBUG] - Multirotor
[20171126 22:52:35.641 INFO ] - QGCMapTool::activeUASSet
[20171126 22:52:35.647 INFO ] - UASActionWidget::activeUASSet
[20171126 22:52:35.650 INFO ] - Arming State Changed: DISARM
[20171126 22:52:35.651 INFO ] - updateWaypointList:
[20171126 22:52:35.652 INFO ] - UASActionWidget: set for Copter
[20171126 22:52:35.675 DEBUG] - APMToolBar::ActiveUASSet ArduPilotMegaMAV(0x94db260)
[20171126 22:52:35.676 DEBUG] - APMToolBar::ActiveUASSet ArduPilotMegaMAV(0x94db260)
[20171126 22:52:35.679 DEBUG] - activeUASSet “MAV 001”
[20171126 22:52:35.681 DEBUG] - UPDATE WP LIST IN 2D MAP CALLED FOR UAS 1
[20171126 22:52:35.686 DEBUG] - HBD: Heartbeat started
[20171126 22:52:35.687 DEBUG] - UAS: new system_status 3
[20171126 22:52:35.689 DEBUG] - UAS: new base mode 81
[20171126 22:52:35.690 DEBUG] - MODE: 81
[20171126 22:52:35.692 DEBUG] - “D|STABILIZED”
[20171126 22:52:35.693 DEBUG] - UAS: new custom mode 0
[20171126 22:52:35.694 DEBUG] - APM: getCustomModeText()
[20171126 22:52:35.696 DEBUG] - plotTextArrow: 0 to “MODE”
[20171126 22:52:35.698 DEBUG] - APMToolBar::mode: “Stabilize”
[20171126 22:52:35.699 DEBUG] - APM: getCustomModeText()
[20171126 22:52:35.700 DEBUG] - APM say: “Mode changed to Stabilize for system 1”
[20171126 22:52:36.644 DEBUG] - “retrieve versionobject from server: http://firmware.ardupilot.org/Tools/APMPlanner/apm_planner_version.json”
[20171126 22:52:37.029 DEBUG] - Downloading: 2838 / 2838
[20171126 22:52:37.030 DEBUG] - Downloading: 2838 / 2838
[20171126 22:52:37.032 DEBUG] - AutoUpdateCheck::httpFinished()
[20171126 22:52:37.035 DEBUG] - Detected newVersion: (“2.0.24”, “2.0.24”, “”) count: 2
[20171126 22:52:37.036 DEBUG] - Detected currentVersion: (“2.0.24”, “2.0.24”, “”) count: 2
[20171126 22:52:37.037 DEBUG] - Verison Compare: " New Version 2.0.24 compared to Old Version 2.0.24"
[20171126 22:52:37.038 INFO ] - no new update available
[20171126 22:52:45.512 DEBUG] - QGCParamWidget: No parameters, re-requesting from MAV
[20171126 22:52:45.513 DEBUG] - src\uas\UAS.cc 2160 LOADING PARAM LIST
[20171126 22:52:46.209 DEBUG] - ApmSoftwareConfig::populateTimerTick() - No Param names from param manager. Sleeping for one second…
[20171126 22:52:47.219 DEBUG] - ApmSoftwareConfig::populateTimerTick() - No Param names from param manager. Sleeping for one second…
[20171126 22:52:49.490 DEBUG] - HBD: Heartbeat stopped
[20171126 22:52:49.515 DEBUG] - HBD: Heartbeat started
[20171126 22:52:50.486 DEBUG] - ApmSoftwareConfig::populateTimerTick() - No Param names from param manager. Sleeping for one second…
[20171126 22:52:51.483 DEBUG] - ApmSoftwareConfig::populateTimerTick() - No Param names from param manager. Sleeping for one second…
[20171126 22:52:52.480 DEBUG] - ApmSoftwareConfig::populateTimerTick() - No Param names from param manager. Sleeping for one second…
[20171126 22:52:53.480 DEBUG] - ApmSoftwareConfig::populateTimerTick() - No Param names from param manager. Sleeping for one second…
[20171126 22:52:54.478 DEBUG] - ApmSoftwareConfig::populateTimerTick() - No Param names from param manager. Sleeping for one second…
[20171126 22:52:54.770 DEBUG] - mousePressEvent pos: QPoint(597,466) posF: QPoint(597,466)
[20171126 22:52:54.960 DEBUG] - mouseReleaseEvent pos: QPoint(597,466) posF: QPoint(597,466)
[20171126 22:52:55.480 DEBUG] - ApmSoftwareConfig::populateTimerTick() - No Param names from param manager. Sleeping for one second…
[20171126 22:52:55.512 DEBUG] - QGCParamWidget: No parameters, re-requesting from MAV
[20171126 22:52:55.514 DEBUG] - src\uas\UAS.cc 2160 LOADING PARAM LIST
[20171126 22:52:56.492 DEBUG] - ApmSoftwareConfig::populateTimerTick() - No Param names from param manager. Sleeping for one second…
[20171126 22:52:57.491 DEBUG] - ApmSoftwareConfig::populateTimerTick() - No Param names from param manager. Sleeping for one second…
[20171126 22:52:58.501 DEBUG] - ApmSoftwareConfig::populateTimerTick() - No Param names from param manager. Sleeping for one second…
[20171126 22:52:59.490 DEBUG] - ApmSoftwareConfig::populateTimerTick() - No Param names from param manager. Sleeping for one second…
[20171126 22:53:00.491 DEBUG] - ApmSoftwareConfig::populateTimerTick() - No Param names from param manager. Sleeping for one second…
[20171126 22:53:01.494 DEBUG] - ApmSoftwareConfig::populateTimerTick() - No Param names from param manager. Sleeping for one second…
[20171126 22:53:02.490 DEBUG] - ApmSoftwareConfig::populateTimerTick() - No Param names from param manager. Sleeping for one second…
[20171126 22:53:03.489 DEBUG] - ApmSoftwareConfig::populateTimerTick() - No Param names from param manager. Sleeping for one second…
[20171126 22:53:04.504 DEBUG] - ApmSoftwareConfig::populateTimerTick() - No Param names from param manager. Sleeping for one second…
[20171126 22:53:05.504 DEBUG] - ApmSoftwareConfig::populateTimerTick() - No Param names from param manager. Sleeping for one second…
[20171126 22:53:05.517 DEBUG] - QGCParamWidget: No parameters, re-requesting from MAV
[20171126 22:53:05.517 DEBUG] - src\uas\UAS.cc 2160 LOADING PARAM LIST
[20171126 22:53:06.504 DEBUG] - ApmSoftwareConfig::populateTimerTick() - No Param names from param manager. Sleeping for one second…
[20171126 22:53:07.516 DEBUG] - ApmSoftwareConfig::populateTimerTick() - No Param names from param manager. Sleeping for one second…
[20171126 22:53:08.531 DEBUG] - ApmSoftwareConfig::populateTimerTick() - No Param names from param manager. Sleeping for one second…
[20171126 22:53:10.218 DEBUG] - ApmSoftwareConfig::populateTimerTick() - No Param names from param manager. Sleeping for one second…
[20171126 22:53:11.228 DEBUG] - ApmSoftwareConfig::populateTimerTick() - No Param names from param manager. Sleeping for one second…
[20171126 22:53:12.230 DEBUG] - ApmSoftwareConfig::populateTimerTick() - No Param names from param manager. Sleeping for one second…
[20171126 22:53:13.242 DEBUG] - ApmSoftwareConfig::populateTimerTick() - No Param names from param manager. Sleeping for one second…
[20171126 22:53:14.240 DEBUG] - ApmSoftwareConfig::populateTimerTick() - No Param names from param manager. Sleeping for one second…
[20171126 22:53:15.255 DEBUG] - ApmSoftwareConfig::populateTimerTick() - No Param names from param manager. Sleeping for one second…
[20171126 22:53:15.525 DEBUG] - QGCParamWidget: No parameters, re-requesting from MAV
[20171126 22:53:15.527 DEBUG] - src\uas\UAS.cc 2160 LOADING PARAM LIST
[20171126 22:53:16.257 DEBUG] - ApmSoftwareConfig::populateTimerTick() - No Param names from param manager. Sleeping for one second…
[20171126 22:53:17.270 DEBUG] - ApmSoftwareConfig::populateTimerTick() - No Param names from param manager. Sleeping for one second…
[20171126 22:53:18.285 DEBUG] - ApmSoftwareConfig::populateTimerTick() - No Param names from param manager. Sleeping for one second…
[20171126 22:53:19.301 DEBUG] - ApmSoftwareConfig::populateTimerTick() - No Param names from param manager. Sleeping for one second…
[20171126 22:53:20.307 DEBUG] - ApmSoftwareConfig::populateTimerTick() - No Param names from param manager. Sleeping for one second…
[20171126 22:53:21.315 DEBUG] - ApmSoftwareConfig::populateTimerTick() - No Param names from param manager. Sleeping for one second…
[20171126 22:53:22.330 DEBUG] - ApmSoftwareConfig::populateTimerTick() - No Param names from param manager. Sleeping for one second…
see the settings on 2 modules
