Having problem to make work both at the same time, Both work well alone…
I do have a Y connector going out of the APM with GND/+5/Tx/Rx going to minimosd and telemetry 3dr,
When each add-on plug seperately work fine, but together not working ether i lose 3dr telem or screen display on minimosd,
When 3dr telem work with GND/+5/TX/RX and adding minimosd with same Y (without tx on minimosd) going to APM = 3dr telemetry goes down no communication and minimosd work fine.
When Minimosd work with GND/+5/RX and TX and adding 3dr telemetry with same Y (including TX) going to APM = I lose minimosd screen display and unable to connect with PC to 3dr telem.
For the moment we’ll just accept that you have the GND and +5v connected to both the Telemetry Radio (now to be referred to as TR) and to the MinimOSD (now to be referred to as OSD). The correct connection should be:
APM TX > TR-RX + OSD-RX
APM RX > TR-TX Only
Are you making the correct connections RX-TX and TX-RX as shown above, not TX-TX and RX-RX?
