Hello, thank you very much for reading my post.
I need help with a 3DR iris+ that has a possible voltage issue.
I bought this drone with this fault and with more than 20 years of experience repairing computers and recovering data, I said to myself: how difficult can it be?
When connecting the battery the led turns on and off in yellow, when pressing the button to arm the led remained the same, when reviewing the Mission Planner messages I found that it indicated: GPS 2: was not found. So I had to disarm the drone, check that everything was well connected and found that there is only one GPS module installed. So I had to go into settings where I found there were 3 compasses enabled, disable number 3 and disable GPS 2 and did the compass calibration, with this the GPS 2 error disappeared.
With this, when connecting the battery and after pressing the button, the LED now flashes green, but I cannot assemble the motors.
When checking Mission Planner, the Preflight indicates that the battery level is 10.34 volts, the station indicates that the voltage is 10.34 volts with 99 mAh (if it is left connected for a while, this value increases). So I got a battery tester, the battery indicates that it has 12.5 volts, and the 3 cells have more than 4 volts each, unfortunately I don’t have an ammeter to check the amps.
I tried another battery, check that the level of the cells is ok and the same thing happens.
Since I use 1.2 volt rechargeable AA batteries, I thought that these 10.34 volts corresponded to the voltage level in the transmitter batteries, but when checking the manual it indicates that the buzzer activates when the voltage is lower than 8.5 volts.
What do you recommend I check? Do you recommend testing the transmitter with 1.5 volt batteries? Do I have a voltage board problem and need to repair a component or replace the board? Or do you think it is due to a configuration problem within the mission planner configuration?
Thank you very much for your help
Regards
