3DR GPS Lea6 v1.1 with APM 2.5
After a crash, I notice the battery has come loose from the board, but the battery is still attached to the strap on the top. I taped it down for now. I started up the APM with GPS, and all works. What is the battery for? Can I live with out it? How do I permanently fix it to the board??
Thanks, Brian
@norman_ok,
The battery is for the onboard volatile memory that is used to store the satellite almanac which allows for a shorter cold/warm startup. If the battery is not connected properly to the pwb, the volatile memory will not be sustained when the GPS is not powered by the APM.
Regards,
TCIII Developer
