I cannot get my tablet with windows9 to link up with the 3dr antenna. I have the baud rate set correctly at 57600 and the usb connection is live on the unit. I downloaded the driver from 3dr but it still does not work. Has anyone else had the same problem with a windows tablet and are there any fixes?
Hi Windmill, re-install your drivers via Device Manager and try a different USB cable.
Unfortunatly that doesn’t work.
Using MP, configure your remote antenna as the primary with a USB cable.
Disconnect the USB from the remote antenna and connect to your local antenna.
Configure it the same way.
Don’t know why it works; it works for me whenever I introduce a new antenna to the system. The good news is that once they see each other, they continue to see each other.
