Hi everyone! I have a Mateksys F765WSE FC, a set of 3DR telemetry modules and Arduplane firmware. In one moment, telemetry refuse to execute the command. Getting the orientation parameters is fine. I swap telemetry module, checked all the wiring, but the telemetry cannot get a signal from the GCS to the aircraft. When I press the relay or want to change flight mode - nothing happens and becomes the next message:
**The Command failed to execute **.
System TimeoutException : Timeout on read - doCommand s Mission Planner MAVLinkInterface . < doCommandAsync > d_194 . MoveNext ( ) в C : \ Users \ mich1 \ Desktop \ CubePilot Mission Planner \ ExtLibs \ ArduPilot Mavlink \ MAVLinkInterface.cs : cTpоka 2541 — Kонеч трассиовка стека из предыдушеrо pасnoложения , где возникло исключение B System.Runtime . Exception Services . Exception Dispatchinfo.Throw ( ) B System.Runtime.Compiler Services . TaskAwaiter.HandleNonSuccess And Debugger Notification ( Task task ) Extensions . < > c_DisplayClass1_0`1 . << AwaitSync > b_0 > d.MoveNext ( ) в C : \ Users \ mich1 \ Desktop \ CubePilot Mission Planner \ ExtLibs Utilities \ Extensions.cs : Cтpоka 113 — Kонеш трассиоовка стека из предыдушего расположения , где воиникло исключение — B Mission Planner.Utilities . B System.Runtime . Exception Services . Exception Dispatchinfo . Throw ( ) B System.Runtime.Compiler Services . TaskAwaiter.HandleNonSuccess And Debugger Notification ( Task task ) B Mission Planner . Utilities . Extensions.AwaitSync [ T ] ( Task 1 infunc ) в C : \ Users \ mich1 \ Desktop \ CubePilot Mission Planner \ ExtLibs \ Utilities Extensions.cs : very 116 B Mission Planner.Controls . RelayOptions.BUT Low_Click ( Object sender , EventArgs e ) в
