On a Pixhawk 1, loaded with Plane 3.8.2, and an i2c connected OLED display, the first column of the display is corrupted.
The same Pixhawk 1 running copter displays with no problems.
Second display tried on Pixhawk 1 and the same corrupted first column appears.
The same 2 displays tried on Pixhawk 2.1 the display has no problems on plane 3.8.2.
Initially copter was loaded and all worked as expected but with no changes, nothing unplugged or plugged in, and plane installed, the display showed the corrupted 1st column.
