Dear all
I may need some help trying to investigate the problem that this morning almost destroy my X8.
I am running Pixhawk with Fw3.3 rc7, dual ublox neo-m8 on x8 coaxial.
I was testing pid in althold for few minutes and then I switch to loiter. After few second at about 3-4 meter AGL the copter roll suddenly
I immediately try to investigate for hdop and visible satelite numbers, but everything seems to be fine.
The only really strange reading that I found is the altitude that somehow rise to 7 meter and there stay even after crash… while Pixhawk still recording and alive.
I wouldn’t call that a fly away. A fly away is when the copter does exactly that. Flies away from you until it runs out of battery and usually you never see it again. This was a crash.
this a X8 copter running Hobbywings xrotor-40pro ESC and DYS 4114-400kv motor
The pixhawk is powered by a separate 3 amps UBEC @5V (max 5 amps).
I noticed that the log is not complete but looking at the board voltage is fixed at 5 volts till the end of the registered log.
When the copter crash, the pixhawk was alive and emitting beep, therefore if the case of a power failure I would have expected a voltage board below 5 v. Would you agree?
What do you mean “minimum throttle is set high enough” ? I’ve done the esc calibration and set THR_MID to adjusted value after hovering in Stabilize, is that what you mean?
Min Throttle should be set so when the stick is above 0% any motor will never stop spinning asto not have ESC Sync issues. I had this issue with one of my quads.
Basically go to the setup page and where it says “motor test” see what % Of throttle is needed to ensure themotor spins up properly each time you push the button, then set that value for your minimum throttle, or a bit above it.
Yesterday I also checked other logs and discovered a couple of occurence of the error “PM = slow loop lines was found”, So looking at the SDcard and I noticed that altough I bought the Pixhawk from 3DR, there was installed a NON “certified” sdcard.
Not a big deal but I was expected to have some “approved” hardware compatibility buyibg from 3DR
Anyhow, just to be sure I am going to swap to a Kingston class 10
