I have been succesfully running 3.2rc2 on 2 pixhawks, downloading logs without issue. Decided to try 3.2 on an APM2.6, and no matter what I do it refuses to download the logs through USB.
Anything I am missing here?
no one?
[nobeta][/nobeta]
[infocopter][/infocopter]
Hi Stefan,
I fully understand this is Release Candidate software, the only reason I am running it is to help the project and progress the version release. I was under the impression this is the place to post issues as they are found.
I canât give you logs, so the only additional info I can provide is:
-Mission planner version 1.3.5 build 1.1.5260.33055.
-Windows 8 64bit.
-APM 2.6 with external mag.
Thanks for your help -
How do you try to download the logs? Can you describe your steps?
I plug in the usb, and under âterminalâ, I immediately press âlog downloadâ. Since upgrading the 3.2rc2, all I see is scrolling text.
If i plug in my 3.1.5 APM, or 2 other pixhawks running 3.2rc2 there is no issue. Iâve tried to re-load 3.2rc2 as well on the APM in question.
I also cannot get into CLI as the same thing occurs. I press âconnectâ immediately after plugging/powering the APM, and all I see is scrolling text. Pressing âenterâ, or clicking âshow settingsâ or âtestsâ does nothing
The CLI was removed from the APM version of AC from 3.2 on to save space. Log download goes now via MAVLink. In the MP flight display page is a tab âDataflash logsâ below the attitude indicator.
See #11 at viewtopic.php?f=100&t=7872
thank you for that! Unfortunately still no luck⌠I am able to list the logs, but downloading any of the 7 available - either individually or choosing âdownload all logsâ, it starts the download but eventually give me a âTimeout on Read -GetLogâ (image attached).
should i change radio settings?
anyone have any idea?
Hi rapph
I have had the same problem.
Finally I changed in 3DR Radio Settings Mavlink from Mavlink to Raw Data.
Now it worked without issue.
regards
Andreas
Andreas,
Thank you for tip! I actually found that disabling ECC on both sides did the trick for me.
Best,
Raph
Iâve tried the rawdata option and still I get the timeout error.
This is on all my APMs and Pixhawks - canât download logs!!!
Please help, anyone?
EDIT: Thanks raphh, I tried your tip with the ecc disabling and it works fine now!
