I am trying to use RTK on the 2nd GPS and am having no luck!
My setup is as follows:
Holybro Pixhawk4
Pixhawk4 GPS module
Emlid M+ RTK (2nd GPS)
Emlid RS (BASE)
FRAME is a BOAT using skidsteer control
I have a SONAR connected to Telem2 port using a TTL converter
Setup as:
RNGFND1_TYPE 17
SERIAL2_BAUD 4
SERIAL2_PROTOCOL 9
I get SONAR RANGE DATA in MP.
I have made a 6pin connector cable connecting as follows
[Pixhawk] [EMLID]
(1)5v--------------------------(6)
(2)TX-------------------------(5)RX
(3)RX-------------------------(4)TX
(6)GND-----------------------(1)
Settings all setup in EMLID REACH interface as follows:
BASE - TCP mode - RTCM
ROVER - correction input UART/38400/RTCM
- position output UART/38400/NMEA
I have connected the BASE in the RTK INJECT settings and get data showing in MP.
I have setup the MP parameters as follows:
SERIAL4_BAUD 38
SERAIL4_PROTOCOL 20
GPS_TYPE2 5
GPS_AUTO_SWITCH 1
GPS_INJECT 1
As far as I can tell there is nothing else which needs to be set for this to work.
I get no Corrections coming to the M+ in the EM LID REACH app
I get no HDOP2 values
I get only a single GPS value in the GREEN display window on MP.
I have tried using a different EMLID M+ unit - this doesnt change anything
I have also tried using different cables
I have reflashed the PIXHAWK and manually reset all the settings.
Nothing I try will work? Is the PIXHAWK faulty UART port???
