When assembling the motor arms I found the wires sit right in the way of where the screw needs to go, I do not want to twist the wires too much. Any suggestions?
I had this issue as well, what I found was that if you pull them out of the way a little bit temporarily, they can still rest partially over the top of the screw. It was a bit nail-biting but it worked.
I am also thinking that vibration from the motor may eventually cut into the wire.
I was told the motor brackets were really for X8 and not needed for X4. I removed them to save some weight.
