I’m working on a design for a tilt-wing aircraft. I’m trying to minimize weight and drag associated with the VTOL hardware. Is it possible to configure a 2-motor tilt-wing?
I know I could do a 3-motor tilt wing but the third motor add weight/drag depending on setup. A bicopter would be possible but, again it adds the weight of a second tilt servo.
I was thinking of 2 motors that tilt with the wing and then control yaw through the ailerons while in vertical flight.
