I have the same problem. I think APM Planner is confused by the node ID number that precedes every output line. That’s not present in v1.9. Here’s the log output:
[size=85]DEBUG 2015-03-06T16:21:30.750 MODE: 0
DEBUG 2015-03-06T16:21:30.750 "D|PREFLIGHT"
DEBUG 2015-03-06T16:21:30.750 MODE: 80
DEBUG 2015-03-06T16:21:30.750 "D|STABILIZED"
DEBUG 2015-03-06T16:21:30.750 MODE: 64
DEBUG 2015-03-06T16:21:30.751 "D|MANUAL"
DEBUG 2015-03-06T16:21:30.751 MODE: 88
DEBUG 2015-03-06T16:21:30.751 "D|VECTOR|STABILIZED"
DEBUG 2015-03-06T16:21:30.751 MODE: 92
DEBUG 2015-03-06T16:21:30.751 "D|AUTO|STABILIZED"
DEBUG 2015-03-06T16:21:30.751 MODE: 66
DEBUG 2015-03-06T16:21:30.751 "D|TEST"
DEBUG 2015-03-06T16:21:30.783 QUrl( “file:///Applications/APM Planner 2.0.app/Contents/MacOS/qml/PrimaryFlightDisplayQML.qml” )
DEBUG 2015-03-06T16:21:31.846 QML Status: 1
DEBUG 2015-03-06T16:21:31.847 QUrl( “file:///Applications/APM Planner 2.0.app/Contents/MacOS/qml/PrimaryFlightDisplayQML.qml” )
DEBUG 2015-03-06T16:21:31.881 QML Status: 1
INFO 2015-03-06T16:21:31.886 UASActionsWidget creating UASActionsWidget(0x10fd570c0)
DEBUG 2015-03-06T16:21:31.888 QuickView: load settings
DEBUG 2015-03-06T16:21:31.888 QuickView: loading key: “GCS Status.Altitude (GPS) (m)” type: "text"
DEBUG 2015-03-06T16:21:31.890 QuickView: loading key: “GCS Status.Altitude (REL) (m)” type: "text"
DEBUG 2015-03-06T16:21:31.891 QuickView: loading key: “GCS Status.Battery (%)” type: "text"
DEBUG 2015-03-06T16:21:31.893 QuickView: loading key: “GCS Status.Climb (m/s)” type: "text"
DEBUG 2015-03-06T16:21:31.895 QuickView: loading key: “GCS Status.Current (A)” type: "text"
DEBUG 2015-03-06T16:21:31.897 QuickView: loading key: “GCS Status.GPS Fix ()” type: "text"
DEBUG 2015-03-06T16:21:31.900 QuickView: loading key: “GCS Status.GPS HDOP (m)” type: "text"
DEBUG 2015-03-06T16:21:31.902 QuickView: loading key: “GCS Status.GPS Sats ()” type: "text"
DEBUG 2015-03-06T16:21:31.905 QuickView: loading key: “GCS Status.Pitch (deg)” type: "text"
DEBUG 2015-03-06T16:21:31.907 QuickView: loading key: “GCS Status.Roll (deg)” type: "text"
DEBUG 2015-03-06T16:21:31.910 QuickView: loading key: “GCS Status.Voltage (V)” type: "text"
DEBUG 2015-03-06T16:21:31.913 QuickView: loading key: “GCS Status.Yaw (deg)” type: "text"
DEBUG 2015-03-06T16:21:31.918 QuickView: load settings END
DEBUG 2015-03-06T16:21:31.971 qmlBaseDir "/Applications/APM Planner 2.0.app/Contents/MacOS"
DEBUG 2015-03-06T16:21:31.971 QUrl( “file:///Applications/APM Planner 2.0.app/Contents/MacOS/qml/ApmToolBar.qml” )
DEBUG 2015-03-06T16:21:31.997 QML Status: 1
DEBUG 2015-03-06T16:21:32.001 Loading widget: "PRIMARY_FLIGHT_DISPLAY_QML_DOCKWIDGET"
DEBUG 2015-03-06T16:21:32.001 Loading widget: "UAS_INFO_INFOVIEW_DOCKWIDGET"
INFO 2015-03-06T16:21:33.381 “Bluetooth-Incoming-Port” 115200
DEBUG 2015-03-06T16:21:33.384 APMToolBar: new Serial Link Created 1
DEBUG 2015-03-06T16:21:33.384 APMToolBar setConnection: false
DEBUG 2015-03-06T16:21:33.385 APMToolBar: updateLinkDisplay “” 115200 false
INFO 2015-03-06T16:21:33.386 UDP Created "UDP Link (port:14550)"
INFO 2015-03-06T16:21:33.387 UDP disconnect
INFO 2015-03-06T16:21:33.387 UDPLink::UDP connect QHostAddress( “0.0.0.0” ) : 14550
ERROR 2015-03-06T16:21:33.387 bind failed! QHostAddress( “0.0.0.0” ) : 14550
DEBUG 2015-03-06T16:21:33.400 SCW: Link is disconnected
DEBUG 2015-03-06T16:21:33.402 Baud rate: 115200 Expected: 4
DEBUG 2015-03-06T16:21:37.870 "retrieve versionobject from server: firmware.diydrones.com/Tools/APM … rsion.json"
DEBUG 2015-03-06T16:21:38.169 Downloading: 1147 / 4156
DEBUG 2015-03-06T16:21:38.171 Downloading: 4156 / 4156
DEBUG 2015-03-06T16:21:38.172 AutoUpdateCheck::httpFinished()
DEBUG 2015-03-06T16:21:38.193 Detected newVersion: (“2.0.15”, “2.0.15”, “”) count: 2
DEBUG 2015-03-06T16:21:38.193 Detected currentVersion: (“2.0.15”, “2.0.15”, “”) count: 2
DEBUG 2015-03-06T16:21:38.193 Verison Compare: " New Version 2.0.15 compared to Old Version 2.0.15"
INFO 2015-03-06T16:21:38.193 no new update available
DEBUG 2015-03-06T16:21:41.489 3DR Radio Start Serial Port Scanning
INFO 2015-03-06T16:21:47.557 read 3DR Radio Settings
DEBUG 2015-03-06T16:21:47.562 Radio3DRSettings Serial Port Open SUCCESS "usbserial-DN006VFG"
DEBUG 2015-03-06T16:21:47.562 Port “usbserial-DN006VFG” 115200 8 FC 0 P 0 SB 1
INFO 2015-03-06T16:21:47.563 Port Configured with success
DEBUG 2015-03-06T16:21:47.563 Radio3DRSettings::writeEscapeSeqeunce()
DEBUG 2015-03-06T16:21:47.563 local status: "entering command mode"
INFO 2015-03-06T16:21:47.563 Retry 1
DEBUG 2015-03-06T16:21:48.641 Radio3DRSettings::writeEscapeSeqeunceNow()
DEBUG 2015-03-06T16:21:49.641 Radio readData currentline: "[0] OK
INFO 2015-03-06T16:21:49.642 3DR Radio: Entered Command Mode
DEBUG 2015-03-06T16:21:49.642 local status: "Entered Command mode"
DEBUG 2015-03-06T16:21:49.642 Radio3DRSettings::readLocalVersionString()
DEBUG 2015-03-06T16:21:49.642 local status: "Read local radio version"
DEBUG 2015-03-06T16:21:49.660 Radio readData currentline: "ATI0
DEBUG 2015-03-06T16:21:49.660 Radio readData nextline: “[0] MP SiK 2.3 on RFD900A
” [/size]
