Originally thought the motor dead. Tested with other esc to make sure it wasnt the esc and noticed it would turn left and arm fine but when I reversed the direction it won’t turn right it will just twitch on arm. Have calibrated esc multiple times through mission planner (once manually during initial setup). This all started after a failed first take off and it flipped the motor was working before.
Edit 2: I changed the motor location and now it refuses to spin left and will only twitch right seems maybe the motor will only try to spin in the opposite direction healthy to the quad.
Edit 3: Motor will spin right sometimes but only when given throttle not on arm
