X8 octa-quad SITL gazebo
Hello again. I have changed the size of the Iris to 1.5 1.6 1 to resemble my drone (and the other values above as I mentioned earlier.) It takes off but it starts to take a big angle and eventually crashes, right after it reaches the desired height.
AP: Vibration compensation ON
height 5
AP: Crash: Disarming: AngErr=172>30, Accel=0.3<3.0
When I change the propellers parameters and inertia I have this issue, so I guess the cp and area are not correct? As I said earlier I tried to do the scaling you proposed on an other thread, depending on my motors.
Any help will be appreciated.
The easiest way to help is if you can share the SDF of the copter you are trying to simulate. That way it will be possible to replicate the set up, and try and fix configuration issues. It’s difficult to do this without the model.
Here are the sdf files:
Iris with ardupilot
<?xml version="1.0"?>
<sdf version="1.9">
  <model name="iris_with_ardupilot">
    <include>
      <uri>model://iris_with_standoffs</uri>
    </include>
    <!-- plugins -->
    <plugin filename="gz-sim-joint-state-publisher-system"
      name="gz::sim::systems::JointStatePublisher">
    </plugin>
    <plugin filename="gz-sim-lift-drag-system"
        name="gz::sim::systems::LiftDrag">
      <a0>0.3</a0>
      <alpha_stall>1.4</alpha_stall>
      <cla>4.2500</cla>
      <cda>0.10</cda>
      <cma>0.0</cma>
      <cla_stall>-0.025</cla_stall>
      <cda_stall>0.0</cda_stall>
      <cma_stall>0.0</cma_stall>
      <area>0.0144</area>
      <air_density>1.2041</air_density>
      <cp>0.3024 0 0</cp>
      <forward>0 1 0</forward>
      <upward>0 0 1</upward>
      <link_name>iris_with_standoffs::rotor_1_link</link_name>
    </plugin>
      <a0>0.3</a0>
      <cla>4.2500</cla>
      <cda>0.10</cda>
      <cma>0.0</cma>
      <area>0.0144</area>
      <cp>-0.3024 0 0</cp>
      <forward>0 -1 0</forward>
    </plugin>
      <a0>0.3</a0>
      <cla>4.2500</cla>
      <cda>0.10</cda>
      <cma>0.0</cma>
      <area>0.0144</area>
      <cp>0.3024 0 0</cp>
      <link_name>iris_with_standoffs::rotor_2_link</link_name>
    </plugin>
      <a0>0.3</a0>
      <cla>4.2500</cla>
      <cda>0.10</cda>
      <cma>0.0</cma>
      <area>0.0144</area>
    </plugin>
      <a0>0.3</a0>
      <cla>4.2500</cla>
      <cda>0.10</cda>
      <cma>0.0</cma>
      <area>0.0144</area>
      <cp>0.3024 0 0</cp>
      <link_name>iris_with_standoffs::rotor_3_link</link_name>
    </plugin>
      <a0>0.3</a0>
      <cla>4.2500</cla>
      <cda>0.10</cda>
      <cma>0.0</cma>
      <area>0.0144</area>
    </plugin>
      <a0>0.3</a0>
      <cla>4.2500</cla>
      <cda>0.10</cda>
      <cma>0.0</cma>
      <area>0.0144</area>
      <cp>0.3024 0 0</cp>
      <link_name>iris_with_standoffs::rotor_4_link</link_name>
    </plugin>
      <a0>0.3</a0>
      <cla>4.2500</cla>
      <cda>0.10</cda>
      <cma>0.0</cma>
      <area>0.0144</area>
    </plugin>
      <a0>0.3</a0>
      <cla>4.2500</cla>
      <cda>0.10</cda>
      <cma>0.0</cma>
      <area>0.0144</area>
      <cp>0.3024 0 0</cp>
      <link_name>iris_with_standoffs::rotor_5_link</link_name>
    </plugin>
      <a0>0.3</a0>
      <cla>4.2500</cla>
      <cda>0.10</cda>
      <cma>0.0</cma>
      <area>0.0144</area>
    </plugin>
      <a0>0.3</a0>
      <cla>4.2500</cla>
      <cda>0.10</cda>
      <cma>0.0</cma>
      <area>0.0144</area>
      <cp>0.3024 0 0</cp>
      <link_name>iris_with_standoffs::rotor_6_link</link_name>
    </plugin>
      <a0>0.3</a0>
      <cla>4.2500</cla>
      <cda>0.10</cda>
      <cma>0.0</cma>
      <area>0.0144</area>
    </plugin>
      <a0>0.3</a0>
      <cla>4.2500</cla>
      <cda>0.10</cda>
      <cma>0.0</cma>
      <area>0.0144</area>
      <cp>0.3024 0 0</cp>
      <link_name>iris_with_standoffs::rotor_7_link</link_name>
    </plugin>
      <a0>0.3</a0>
      <cla>4.2500</cla>
      <cda>0.10</cda>
      <cma>0.0</cma>
      <area>0.0144</area>
    </plugin>
      <a0>0.3</a0>
      <cla>4.2500</cla>
      <cda>0.10</cda>
      <cma>0.0</cma>
      <area>0.0144</area>
      <cp>0.3024 0 0</cp>
      <link_name>iris_with_standoffs::rotor_8_link</link_name>
    </plugin>
      <a0>0.3</a0>
      <cla>4.2500</cla>
      <cda>0.10</cda>
      <cma>0.0</cma>
      <area>0.0144</area>
    </plugin>
    <plugin name="ArduPilotPlugin"
      filename="ArduPilotPlugin">
      <!-- Port settings -->
      <fdm_addr>127.0.0.1</fdm_addr>
      <fdm_port_in>9002</fdm_port_in>
      <connectionTimeoutMaxCount>5</connectionTimeoutMaxCount>
      <lock_step>1</lock_step>
      <have_32_channels>0</have_32_channels>
      <!-- Frame conventions
        Require by ArduPilot: change model and gazebo from XYZ to XY-Z coordinates
      <modelXYZToAirplaneXForwardZDown degrees="true">0 0 0 180 0 0</modelXYZToAirplaneXForwardZDown>
      <gazeboXYZToNED degrees="true">0 0 0 180 0 90</gazeboXYZToNED>
      <!-- Sensors -->
      <imuName>iris_with_standoffs::imu_link::imu_sensor</imuName>
          incoming control command [0, 1]
          so offset it by 0 to get [0, 1]
          and divide max target by 1.
          offset = 0
          multiplier = 838 max rpm / 1 = 838
      <control channel="0">
        <jointName>iris_with_standoffs::rotor_1_joint</jointName>
        <useForce>1</useForce>
        <multiplier>838</multiplier>
        <offset>0</offset>
        <servo_min>1100</servo_min>
        <servo_max>1900</servo_max>
        <type>VELOCITY</type>
        <p_gain>0.20</p_gain>
        <i_gain>0</i_gain>
        <d_gain>0</d_gain>
        <i_max>0</i_max>
        <i_min>0</i_min>
        <cmd_max>2.5</cmd_max>
        <cmd_min>-2.5</cmd_min>
        <controlVelocitySlowdownSim>1</controlVelocitySlowdownSim>
      </control>
      <control channel="1">
        <jointName>iris_with_standoffs::rotor_2_joint</jointName>
        <multiplier>-838</multiplier>
        <offset>0</offset>
        <i_gain>0</i_gain>
        <d_gain>0</d_gain>
        <i_max>0</i_max>
        <i_min>0</i_min>
      </control>
      <control channel="2">
        <jointName>iris_with_standoffs::rotor_3_joint</jointName>
        <offset>0</offset>
        <i_gain>0</i_gain>
        <d_gain>0</d_gain>
        <i_max>0</i_max>
        <i_min>0</i_min>
      </control>
      <control channel="3">
        <jointName>iris_with_standoffs::rotor_4_joint</jointName>
        <offset>0</offset>
        <i_gain>0</i_gain>
        <d_gain>0</d_gain>
        <i_max>0</i_max>
        <i_min>0</i_min>
      </control>
      <control channel="4">
        <jointName>iris_with_standoffs::rotor_5_joint</jointName>
        <offset>0</offset>
        <i_gain>0</i_gain>
        <d_gain>0</d_gain>
        <i_max>0</i_max>
        <i_min>0</i_min>
      </control>
      <control channel="5">
        <jointName>iris_with_standoffs::rotor_6_joint</jointName>
        <offset>0</offset>
        <i_gain>0</i_gain>
        <d_gain>0</d_gain>
        <i_max>0</i_max>
        <i_min>0</i_min>
      </control>
      <control channel="6">
        <jointName>iris_with_standoffs::rotor_7_joint</jointName>
        <offset>0</offset>
        <i_gain>0</i_gain>
        <d_gain>0</d_gain>
        <i_max>0</i_max>
        <i_min>0</i_min>
      </control>
      <control channel="7">
        <jointName>iris_with_standoffs::rotor_8_joint</jointName>
        <offset>0</offset>
        <i_gain>0</i_gain>
        <d_gain>0</d_gain>
        <i_max>0</i_max>
        <i_min>0</i_min>
      </control>
    </plugin>
  </model>
</sdf>
Iris with standoffs
<sdf version="1.9">
  <model name="iris_with_standoffs">
    <pose>0 0 0 0 0 0</pose>
    <link name="base_link">
      <velocity_decay>
        <linear>0.0</linear>
        <angular>0.0</angular>
      </velocity_decay>
      <inertial>
        <mass>68</mass>
        <inertia>
          <ixx>14.73</ixx>
          <ixy>0</ixy>
          <ixz>0</ixz>
          <iyy>13.83</iyy>
          <iyz>0</iyz>
          <izz>22.57</izz>
        </inertia>
      </inertial>
      <collision name="base_collision">
        <pose>0 0 -0.08 0 0 0</pose>
        <geometry>
          <box>
            <size>1.5 1.5 0.9</size>
          </box>
        </geometry>
        <surface>
          <contact>
            <ode>
              <max_vel>100.0</max_vel>
              <min_depth>0.001</min_depth>
            </ode>
          </contact>
          <friction>
            <ode>
              <mu>100000.0</mu>
              <mu2>100000.0</mu2>
            </ode>
          </friction>
        </surface>
      </collision>
      <visual name="base_visual">
        <geometry>
          <mesh>
            <uri>model://iris_with_standoffs/meshes/iris.dae</uri>
          </mesh>
        </geometry>
        <material>
          <ambient>0.05 0.05 0.05</ambient>
          <diffuse>0.05 0.05 0.05</diffuse>
          <specular>1 1 1 1</specular>
          <pbr>
            <metal>
              <metalness>0.5</metalness>
              <roughness>0.5</roughness>
            </metal>
          </pbr>
        </material>
      </visual>
      <visual name="front_left_leg_visual">
        <pose>23 0.22 -0.11 0 0 0</pose>
        <geometry>
          <cylinder>
            <radius>0.005</radius>
            <length>0.17</length>
          </cylinder>
        </geometry>
        <material>
          <specular>0.01 0.01 0.01 1.0</specular>
          <pbr>
            <metal>
            </metal>
          </pbr>
        </material>
      </visual>
      <visual name="front_right_leg_visual">
        <pose>0.123 -0.22 -0.11 0 0 0</pose>
        <geometry>
          <cylinder>
          </cylinder>
        </geometry>
        <material>
          <pbr>
            <metal>
            </metal>
          </pbr>
        </material>
      </visual>
      <visual name="rear_left_leg_visual">
        <pose>-0.140 0.21 -0.11 0 0 0</pose>
        <geometry>
          <cylinder>
          </cylinder>
        </geometry>
        <material>
          <pbr>
            <metal>
            </metal>
          </pbr>
        </material>
      </visual>
      <visual name="rear_right_leg_visual">
        <pose>-0.140 -0.21 -0.11 0 0 0</pose>
        <geometry>
          <cylinder>
          </cylinder>
        </geometry>
        <material>
          <pbr>
            <metal>
            </metal>
          </pbr>
        </material>
      </visual>
    </link>
    <link name="imu_link">
      <inertial>
        <mass>0.15</mass>
        <inertia>
          <ixx>0.00001</ixx>
          <ixy>0</ixy>
          <ixz>0</ixz>
          <iyy>0.00002</iyy>
          <iyz>0</iyz>
          <izz>0.00002</izz>
        </inertia>
      </inertial>
      <sensor name="imu_sensor" type="imu">
        <pose degrees="true">0 0 0 180 0 0</pose>
        <always_on>1</always_on>
        <update_rate>1000.0</update_rate>
      </sensor>
    </link>
    <joint name="imu_joint" type="revolute">
      <child>imu_link</child>
      <parent>base_link</parent>
      <axis>
        <xyz>0 0 1</xyz>
        <limit>
          <lower>0</lower>
          <upper>0</upper>
          <effort>0</effort>
          <velocity>0</velocity>
        </limit>
        <dynamics>
          <damping>1.0</damping>
        </dynamics>
      </axis>
    </joint>
    <link name="rotor_1_link">
      <pose>0.13 -0.22 0.023 0 0 0</pose>
      <inertial>
        <mass>0.2</mass>
        <inertia>
          <ixx>9.75e-06</ixx>
          <ixy>0</ixy>
          <ixz>0</ixz>
          <iyy>0.000166704</iyy>
          <iyz>0</iyz>
          <izz>0.000167604</izz>
        </inertia>
      </inertial>
      <collision name="collision">
        <geometry>
          <cylinder>
            <length>0.005</length>
            <radius>0.46</radius>
          </cylinder>
        </geometry>
        <surface>
          <contact>
            <ode/>
          </contact>
          <friction>
            <ode/>
          </friction>
        </surface>
      </collision>
      <visual name="visual">
        <geometry>
          <mesh>
            <scale>1 1 1</scale>
            <uri>model://iris_with_standoffs/meshes/iris_prop_ccw.dae</uri>
          </mesh>
        </geometry>
        <material>
          <ambient>0 0 1</ambient>
          <diffuse>0 0 1</diffuse>
          <pbr>
            <metal>
            </metal>
          </pbr>
        </material>
      </visual>
      <gravity>1</gravity>
      <velocity_decay/>
      <self_collide>0</self_collide>
    </link>
    <joint name="rotor_1_joint" type="revolute">
      <child>rotor_1_link</child>
      <axis>
        <xyz>0 0 1</xyz>
        <limit>
          <lower>-1e+16</lower>
          <upper>1e+16</upper>
        </limit>
        <dynamics>
          <damping>0.004</damping>
        </dynamics>
      </axis>
      <physics>
        <ode>
          <implicit_spring_damper>1</implicit_spring_damper>
        </ode>
      </physics>
    </joint>
    <link name="rotor_2_link">
      <pose>0.13 0.22 0.023 0 0 0</pose>
      <inertial>
        <mass>0.2</mass>
        <inertia>
          <ixx>9.75e-06</ixx>
          <ixy>0</ixy>
          <ixz>0</ixz>
          <iyz>0</iyz>
        </inertia>
      </inertial>
        <geometry>
          <cylinder>
          </cylinder>
        </geometry>
        <surface>
          <contact>
            <ode/>
          </contact>
          <friction>
            <ode/>
          </friction>
        </surface>
      </collision>
        <geometry>
          <mesh>
            <uri>model://iris_with_standoffs/meshes/iris_prop_cw.dae</uri>
          </mesh>
        </geometry>
        <material>
          <ambient>0 1 0</ambient>
          <diffuse>0 1 0</diffuse>
          <pbr>
            <metal>
            </metal>
          </pbr>
        </material>
      </visual>
      <velocity_decay/>
    </link>
    <joint name="rotor_2_joint" type="revolute">
      <child>rotor_2_link</child>
      <axis>
        <xyz>0 0 1</xyz>
        <limit>
        </limit>
        <dynamics>
        </dynamics>
      </axis>
      <physics>
        <ode>
        </ode>
      </physics>
    </joint>
    <link name="rotor_3_link">
      <pose>-0.13 0.2 0.023 0 0 0</pose>
      <inertial>
        <mass>0.2</mass>
        <inertia>
          <ixx>9.75e-06</ixx>
          <ixy>0</ixy>
          <ixz>0</ixz>
          <iyz>0</iyz>
        </inertia>
      </inertial>
        <geometry>
          <cylinder>
          </cylinder>
        </geometry>
        <surface>
          <contact>
            <ode/>
          </contact>
          <friction>
            <ode/>
          </friction>
        </surface>
      </collision>
        <geometry>
          <mesh>
          </mesh>
        </geometry>
        <material>
          <pbr>
            <metal>
            </metal>
          </pbr>
        </material>
      </visual>
      <velocity_decay/>
    </link>
    <joint name="rotor_3_joint" type="revolute">
      <child>rotor_3_link</child>
      <axis>
        <xyz>0 0 1</xyz>
        <limit>
        </limit>
        <dynamics>
        </dynamics>
      </axis>
      <physics>
        <ode>
        </ode>
      </physics>
    </joint>
    <link name="rotor_4_link">
      <pose>-0.13 -0.2 0.023 0 0 0</pose>
      <inertial>
        <mass>0.2</mass>
        <inertia>
          <ixx>9.75e-06</ixx>
          <ixy>0</ixy>
          <ixz>0</ixz>
          <iyz>0</iyz>
        </inertia>
      </inertial>
        <geometry>
          <cylinder>
          </cylinder>
        </geometry>
        <surface>
          <contact>
            <ode/>
          </contact>
          <friction>
            <ode/>
          </friction>
        </surface>
      </collision>
        <geometry>
          <mesh>
          </mesh>
        </geometry>
        <material>
          <pbr>
            <metal>
            </metal>
          </pbr>
        </material>
      </visual>
      <velocity_decay/>
    </link>
    <joint name="rotor_4_joint" type="revolute">
      <child>rotor_4_link</child>
      <axis>
        <xyz>0 0 1</xyz>
        <limit>
        </limit>
        <dynamics>
        </dynamics>
      </axis>
      <physics>
        <ode>
        </ode>
      </physics>
    </joint>
    <link name="rotor_5_link">
      <pose>0.13 0.22 -0.023 0 0 0</pose>
      <inertial>
        <mass>0.2</mass>
        <inertia>
          <ixx>9.75e-06</ixx>
          <ixy>0</ixy>
          <ixz>0</ixz>
          <iyz>0</iyz>
        </inertia>
      </inertial>
        <geometry>
          <cylinder>
          </cylinder>
        </geometry>
        <surface>
          <contact>
            <ode/>
          </contact>
          <friction>
            <ode/>
          </friction>
        </surface>
      </collision>
        <geometry>
          <mesh>
          </mesh>
        </geometry>
        <material>
          <pbr>
            <metal>
            </metal>
          </pbr>
        </material>
      </visual>
      <velocity_decay/>
    </link>
    <joint name="rotor_5_joint" type="revolute">
      <child>rotor_5_link</child>
      <axis>
        <xyz>0 0 1</xyz>
        <limit>
        </limit>
        <dynamics>
        </dynamics>
      </axis>
      <physics>
        <ode>
        </ode>
      </physics>
    </joint>
    <link name="rotor_6_link">
      <pose>0.13 -0.22 -0.023 0 0 0</pose>
      <inertial>
        <mass>0.2</mass>
        <inertia>
          <ixx>9.75e-06</ixx>
          <ixy>0</ixy>
          <ixz>0</ixz>
          <iyz>0</iyz>
        </inertia>
      </inertial>
        <geometry>
          <cylinder>
          </cylinder>
        </geometry>
        <surface>
          <contact>
            <ode/>
          </contact>
          <friction>
            <ode/>
          </friction>
        </surface>
      </collision>
        <geometry>
          <mesh>
          </mesh>
        </geometry>
        <material>
          <pbr>
            <metal>
            </metal>
          </pbr>
        </material>
      </visual>
      <velocity_decay/>
    </link>
    <joint name="rotor_6_joint" type="revolute">
      <child>rotor_6_link</child>
      <axis>
        <xyz>0 0 1</xyz>
        <limit>
        </limit>
        <dynamics>
        </dynamics>
      </axis>
      <physics>
        <ode>
        </ode>
      </physics>
    </joint>
    <link name="rotor_7_link">
      <pose>-0.13 -0.2 -0.023 0 0 0</pose>
      <inertial>
        <mass>0.2</mass>
        <inertia>
          <ixx>9.75e-06</ixx>
          <ixy>0</ixy>
          <ixz>0</ixz>
          <iyz>0</iyz>
        </inertia>
      </inertial>
        <geometry>
          <cylinder>
          </cylinder>
        </geometry>
        <surface>
          <contact>
            <ode/>
          </contact>
          <friction>
            <ode/>
          </friction>
        </surface>
      </collision>
        <geometry>
          <mesh>
          </mesh>
        </geometry>
        <material>
          <pbr>
            <metal>
            </metal>
          </pbr>
        </material>
      </visual>
      <velocity_decay/>
    </link>
    <joint name="rotor_7_joint" type="revolute">
      <child>rotor_7_link</child>
      <axis>
        <xyz>0 0 1</xyz>
        <limit>
        </limit>
        <dynamics>
        </dynamics>
      </axis>
      <physics>
        <ode>
        </ode>
      </physics>
    </joint>
    <link name="rotor_8_link">
      <pose>-0.13 0.2 -0.023 0 0 0</pose>
      <inertial>
        <mass>0.2</mass>
        <inertia>
          <ixx>9.75e-06</ixx>
          <ixy>0</ixy>
          <ixz>0</ixz>
          <iyz>0</iyz>
        </inertia>
      </inertial>
        <geometry>
          <cylinder>
          </cylinder>
        </geometry>
        <surface>
          <contact>
            <ode/>
          </contact>
          <friction>
            <ode/>
          </friction>
        </surface>
      </collision>
        <geometry>
          <mesh>
          </mesh>
        </geometry>
        <material>
          <pbr>
            <metal>
            </metal>
          </pbr>
        </material>
      </visual>
      <velocity_decay/>
    </link>
    <joint name="rotor_8_joint" type="revolute">
      <child>rotor_8_link</child>
      <axis>
        <xyz>0 0 1</xyz>
        <limit>
        </limit>
        <dynamics>
        </dynamics>
      </axis>
      <physics>
        <ode>
        </ode>
      </physics>
    </joint>
  </model>
</sdf>
Hi @rhys , any news?
facing the same issue how did you able to takeoff I’m also doing kind of a same thing I’m trying to make fly my drone in gazebo sitl show drone take off in tab then it shows potential thrust loss(4) and I don’t see anything in gazebo only my props are rotating but lift takeoff
@Prateek_Tiwari - all I can recommend is to start with the working example that I provided above, and get it running in your environment.
Then compare it to your drone, and understand what is different and systematically work through each of the changes (dimensions, mass, motor PIDs, LiftDrag coefficients, etc).
