It looks like we are using a similar setup in Lua - so I can run some tests on 4.1.5 as well.
The script should run on 4.1 if you swap to use a scripting user parameter in place of the custom named parameter that the 4.2 script adds.
-- add new param MOT_STOP_BITMASK
local PARAM_TABLE_KEY = 75
assert(param:add_table(PARAM_TABLE_KEY, "MOT_", 1), "could not add param table")
assert(param:add_param(PARAM_TABLE_KEY, 1, "STOP_BITMASK", 0), "could not add param")
local stop_motor_bitmask = Parameter()
assert(stop_motor_bitmask:init("MOT_STOP_BITMASK"), "could not find param")
That bit would become this:
assert(stop_motor_bitmask:init("SCR_USER1"), "could not find param")
Why FC just can not turn off oposite motor and stay move with X-frame mixer?
Because then you don’t have alternative yaw order.
