Edit: I was wrong about the other copter working correctly. I’ve done more in-depth tests with the second copter, and the problem is exactly the same (when the drone gets a GPS: 3D Fix the pre-am message “Waiting for Terrain data” appears and ter_pend equals 336).
At least with this I can assume that the problem does not lie in the hardware.
I’ve finally figured out the cause of this problem and I’ve been able to solve it.
When I boot up the Cube running A.C 4.0.3 with a clean and freshly formatted microSD card inside, ArduCopter fails to correctly create the microSD card directories, always failing to create the “TERRAIN” directory. And this is the cause of my problem, as there is no “TERRAIN” directory in the microSD, the terrain data cannot be downloaded, causing the ter_pend value to be stuck at the same number and consequently popping the PreArm message “Waiting for Terrain data”.
If I flash the copter with an older version of ArduCopter (for my tests I have been using A.C 3.6.11), and I boot it up for the first time with the same freshly formatted microSD card. All directories on the microSD card are created correctly and the terrain data starts downloading immediately to the “TERRAIN” folder.
Now if I just delete the terrain data from within the “TERRAIN” folder. And re-flash the copter with A.C 4.0.3 again, everything works correctly as the “TERRAIN” folder already exists in the microSD, and the terrain data can be downloaded without any problem.
I have tested this behavior with more than one copter, and I can confirm that for me the results are always these. So maybe this is a Bug, worth being checked out by some developer. Or at least I hope this can help someone with this same problem.
I’m reviving this subject!
I too am trying to get terrain following to work without the groundstation attached.
I have:
TERRAIN_ENABLE,1
TERRAIN_FOLLOW,1
TERRAIN_OPTIONS,0 (set to 1 prevents download from the GCS)
TERRAIN_SPACING,30
Currently testing this on 4.0.4rc4, but also had been trying with 4.0.3 with the same results.
This is a small quad without telemetry - it would be extremely handy to have terrain following for RTL and failsafe events since this is a hilly/uneven area.
The TERRAIN folder is present on the SD card and I’ve pre-populated it from https://terrain.ardupilot.org/
…and I have also uploaded a large mission and allowed the terrain to download from the GCS via USB cable.
The pending tiles and downloaded tiles does oscillate around the last 56 or so, sometime going down to 0 pending then it will immediately jump up to 56 pending and download them again.
Plane doco talks about the downloaded terrain data being usable even without a GCS connection (such as dropouts in a telemetry link) however I cant see why the terrain functions wouldnt work entirely without a GCS connection once valid data is on the SD card.
TERRAIN_OPTIONS is new and I thought it might prevent AC from waiting for a GCS and just go ahead and use the preloaded terrain data, but it appears to prevent all terrain activity - I’ll test more.
EDIT: the whole time there is “PreArm: Waiting for Terrain data” and we cant arm.
I will also retest with TERRAIN_SPACING,100 and LOG_DISARMED
Any hints, suggestions or otherwise are welcomed.
EDIT: TERRAIN_SPACING,100 and LOG_DISARMED didnt offer any insights. There doesnt appear to be anything special in the .bin file except the recurring “Waiting for Terrain data” message.
Anyone that’s familiar with how this works can feel free to ask for logs or other info.
EDIT with apparent solution: EDIT again - still inconsistent results, NOT solved
This quad without telemtry was able to successfully download terrain data over USB once I disabled the batch logging for Harmonic Notch filter:
INS_LOG_BAT_MASK,0
INS_LOG_BAT_OPT,0
…since Harmonic notch filter was already set up and working OK.
I presume there was just too much activity going on for the poor old Pixfalcon (FMUv2).
Log downloads via USB are now OK too, was a bit dodgy before.
Another quad with telemetry quickly gets “ter_pend” to 0 and “ter_load” 672 with TERRAIN_SPACING,30
We will try test flights tomorrow with and without telemetry.
EDIT: tested this one all OK with and without telemetry. Terrain data remained in place and seemed to be working OK.
FC was CUAV V5 Nano
Harmonic notch filter batch logging or anything else didnt seem to impede the ability to download or retain terrain data.
hello help, i can’t figure out the problem. everything was done according to the instructions, but the terrain folder does not load files, more precisely, one with the name n68e033 is loaded. this file is empty. I went to a site where you can generate tile files but I can not select my coordinates. I am on the Kola Peninsula
