Survey shot & manual shot, both?
Hi Guys,
I have on board a Cube Orange with Herelink and Solex. I need to take both manual and triggered photos in Survey mode
If I’m not mistaken, in survey mode, the trigger acts on 7 but I have set the manual trigger on channel 10 (AUX 2)
In other words, I have to manually set the output parameters based on the type of operation I have to perform.
How can I manage both modes (auto trigger in Survey + manual shot) with Solex’s Cam Shot button only?
There is a lua script that allows you to do both. Maybe you can use that, or adapt it to do what you need
Thanks Amilcarlucas for the indication; Very interesting.
Unfortunately I don’t understand why this work is not both native; After all, take manual photos and take pictures during the survey are two narrow kinship activities.
Do you also have any indication about coming to find this Lua script without overturn the web?
Thanks again :slight_smile:
It’s already in master:
If you need to adapt it, take a look at:
