Great, thanks for the feedback.
Re the waypoint mission disappearing, I tested it on my CubeOrange and couldn’t reproduce the problem. I suspect it is either the GCS or a script that is erasing the mission. If you’re using QGC, I know it has an option to delete the mission but I don’t have many details of this feature. Maybe try testing a couple of reboots with MP? In case it’s the script could you try setting SCR_ENABLE = 0 and then try rebooting, re-uploading, re-booting etc to see if the problem persists?
Re the delay at waypoints I can imagine a few possible causes:
- the pivot turn is too strict in enforcing the angle target
- the pivot turn does not start until the vehicle has stopped (previously it would start the moment the vehicle passed through the WP_RADIUS)
- the SCurve jerk (change in acceleration) is too low. To avoid overloading people with parameters I’ve hard-coded the jerk to 1m/s/s/s. This will make the vehicle’s slow down before the pivot and speed up after the pivot slower than in master.
I suspect the issue is probably 3… I’ll add a jerk parameter and we can play with that to see if it helps. I might also add some debug output so we can easily see what stage of the turn the vehicle is at and where the time is going.
Txs again!
