They run PX4 and they’re fully supported upstream.
Recently I had to implement custom LQR controller in PX4 and I must say that I like uORB messaging. Pub/sub to topics concept is very familiar to those working in ROS or Gazebo. Also the modules that are like ROS packages or Gazebo plugins that you can add easly to the core system. Plus CMake as build system. In general, I must say that for newcomer, especialy for someone with ROS background it’s easier to modify or replace particular component without detailed knowlege of the whole system.
Didn’t see your answer before but it confirms my thoughts.
Interesting since I actually work extremely closely with Airbus…
Cool, Russell Brand is posting on the forum.
henlo wonder what ppl think of this thread nowadays. which has better attitude n altitude controller?
does px4 have this issue? AP_MotorsMatrix: prevent altitude loss when thrust-to-weight is less than 2 by 117-MasterChief · Pull Request #23512 · ArduPilot/ardupilot · GitHub
code is totally different; will need to dig in sometime.
thanks. what makes you think that has the same issue?
i will post there when i get around to using it.
If I’m thinking it right, it’s part of the blending program. But first off, I have in quadplanes, I use a 2:1 thrust to weight ratio. I go more like 1.6-1.7:1 with higher kV quadmotors, i.e. enough to lift to altitude to hover for a short period of time. That’s enough to keep the altitude while it transitions to FW mode. You fix FW throttle percentage and ramp up period via params while the quadmotors’ throttle auto adjusts to maintain altitude and yaw corrections regardless of the throttle position on the Tx, during the transition.
I had built one several years ago that it started to dive during the transition. After making some changes to the blending params, I was able to almost get rid of the diving tendency.
Good luck.
