If you would have read the my post you would have seen that:
No, no need to change to switch hover learn off. Keep it on.
That depends on your ESC/motor/propeller combination, in most cases 60% should be as fine as 50% and itâs probably not the cause of the issue here.
Also since you are using quick-mounts for the props I highly recommend to turn off âBrake On Stopâ, otherwise your props might unscrew themselves when braking! (I made that error once and the prop that went flying almost destroyed a monitor)
Quick question with regarda to TCAL⌠Is the really necessary to perform a tcal when the drone mostly flies in areas where the temperature range is between 10 and 30 degrees Celcius
If you want to takeoff ASAP and want to avoid having IMU inconsistent, aceel inconsistent, gyro inconsistent errors, yes.
I will do it for sure but have not had any of those issues in the 2 years ive had this fc
