Is there a version available for the Nirvana and or FlySkynv 14?
The firmware name was already shortened because of script issues, but I do notice a bug - please can you put it back to how it was but change line 770 to:
int32_t n = strlen(fwver.fw_short_string);
and see if that works
Oh - iām cant see this moment - yes - in code we have
strlen(fwver.fw_string);
but need
Ok - later iām test this and reply you, thanks!
Yes this fix problems!
Good
Thanks, the fix should make it into the next beta.
@Alex,
I have been struggling to get Yaapu working with CRSF Nano. Could you please look at my settings and advice.
One thing I should point out that hex file or hex+bl files wonāt allow me to upload the firmware, so I updated the F765 FC using .apj file. That should not matter, correct?
Here are my settings laid out on a single slide.
I have full RC control but limited telemetry such as GPS, Flight mode, RSS, pitch.
The battery voltage is fleshing 0 to 99%
Did you enable CRSF support in my script by going into the menu in the Tools page?
also please attach your parameters file
@Alex, I have the CRSF support checked āyesā under the tools.
Parameters file attached.GrimReaper CRSF.param (20.8 KB)
this screenshot says youāre using version 1.8.1 which does not support CRSF, you need to use the latest widget found here https://github.com/yaapu/FrskyTelemetryScript/archive/refs/heads/dev.zip
That screen shot is old, I have updated to 1.9.5-dev (bf94571). That is what my screen shows at the moment.
@yapuu: Thanks again for your great work regarding telemetry for TXās - I do use it with ArduPilot, FrSky and TX16S already. But know I am wondering if it is possible to make it work with PX4, crossfire and TX16S also?
Nope, PX4 does not support the passthrough custom telemetry extension
hi all,
Does anyone know if this is included in the arducopter dev firmwares yet? Or have they not incorporated it yet? I dont know enough about reading the code to tellā¦
i cant see the config widget in tools page on my qx7. i grabbed the latest 1.9.5b1, but I only see āYaapu Debugā and āYaapu CRSF Debugā. Do we need to do anything more than simply copying the SD card contents?
getting back into Arducopter after a some time over on betaflight and I am looking forward to getting the Yaapu telem screen running again! Thanks @yaapu for all the work!
@yaapu, That screen shot is old, I have updated to 1.9.5-dev (bf94571). That is what my screen shows at the moment.
Could you please have a look at the parameter files I attached earlier and advice.
Thx
It has been in AC dev versions since last year and works great.
Sorry, canāt help you with QX7 settings as I moved to TX16S, but it used to work for me on QX7 when I still used it.
Iām a bit lost atm.
Iām trying (or at least that is what I think Iām trying) to get the script working wth CRSF.
Using a matek 743 slim with Copter 4.1 dev.
Crossfire nano (CHANNELS 1/2) Connected to Serial 6 on the FC.
Serial 6 is set to CRSF, and the controller works when doing radio calibration.
All ok.
Now with the script on tx16s I have CRSF enabled in the options, but get no feedback on for example the artificial horizon.
Set CRSF to 150Hz and not to use dynamic power.
I see the crossfire related stuff in the sensors but nothing more (like heading, pitch yaw etc)
On another build Iām using mavlink only and also using rc over mavlink. Although not designed to be used with the script, when I power up that quad and look in the sensors it has heading etc info.
When I want the script to work with crossfire is it enough to use only one serial set to crsf Like I have now, or do I need to use another serial set to mavlink tx/rx to make this work?
ALso the RC_Options number gets me confusedā¦ tried various numbers, but have no clue what it should be doing.
Thanx
Did you try more than one version? I once had a dev version flashed with which Yaapu was not receiving anything. After a long search for possible causes I simply tried a different dev version, and it worked again.
256 + the value thatās already set (if any).
I donāt remember what the RC_Options parameter was before I changed itā¦
And yes I tried multiple versionā¦ Iām currently on Copter 4.1dev beta, it might have something to do with the serial port, maybe it is not a DMA portā¦ whatever that may be.
I see that it needs to be in order to work.
@davidbitton How did you wire everything to the Matek743-Slim?
Iām setting up an ardupilot build with a Matek H743-Slim and crossfire, but cannot get it to work.
What serial port did you wire the reciever too? What is you RC_Options number etc etcā¦
Would love to know more as we seem to have the same setup.
That why Iād recommend saving parameters to disk often, that way you can always trace back the changes.
Beta and dev are not the same. Dev versions can be found in the ālatestā folder and are updated daily. Betas are updated every few weeks at the most.
It should work without a DMA port, using one is just preferred.
