Yes tested with CTS-RTS as mentioned above , it did not solve the issue.
I’m running V2.0
So there is a way to reduce the data the Luna’s send over Mavlink Sik Radio
It’s in the planner Tab of mission planner under sensor rate.
Mine was 8 = 64Hz , reduced it for test to 1 = 8Hz.
8Hz is still 8x100 measurements /sec/Luna.!!
Other sensors like esc’s in my case are also affected by changing this setting .
Reducing the 100Hz of the Luna’s to about 10Hz could be an option to not block Mavlink traffic.
But it’s a shame to compromise on what the Luna’s are capable of just to un-block the Mavlink data stream.
I tested a direct serial connection between Pixhawk Telemetry 1 and PC-Mission-planner.
To my surprise this gave the same results as Sik Radio.
So one could say , the Luna’s just produce to much data for Mavlink Telemetry ports apart from the Serial0 (don’t know why other then less devices active).
As a solution i would like an option where one could set amount of packets being sent per sensor or some kind of divider "send 1 of 100 (rangefinder) measurements ".
Any help here on that ?.
Could you test your setup on sensor rate 8 ? on USB . ( planner TAB in mission planner ).
Ill think you get an easy 64Hz there,
Câble, because you wrote it didn’t work
@ppoirier,
Something’s coming i found the (my) solution !.
I already send 2 Luna data with lightning speed over 915Mhz Sik Radio. Its surprising and cant explain it completely.
Oh… interesting !
Standing by for more
@ppoirier so here it the solution for me (s)
As my serial cable link was as “bad” as the SIK air links 433Mhz ,915Mhz and 2.4Ghz i started to suspect my serial port Telem.1 .
I switched from 1 to Telem 2 and most of my airspeed problems where gone , i can’t really say why …port settings are the same apart from the serial pass settings.
After this “huray” moment i ran into a different problem .Regarding the luna’s Below the settings that worked on USB-> Pixhawk previous.
On Telem.2 this did not work , RNG3 &7 where mixing up all over…an where only one at a time could be seen on Mission-planner and an alarm "sensor x not found sounded on and on ( even sensor that i saw moving on screen)
So next thing i did was giving the sensor with the well know Arduino script again new addresses.
But this time clockwise 16->18>20 ( more logical ).
Still the same problems existed .
Last option was for me to try to change the order in Mission-planner so RNG1->16 RNG2-18 and RNG3->20 and point these in the right direction…
This is the result !,3x Luna’s on 100Hz and on 915Mhz , 57600 bps , airspeed 64. ( so some room left to improve ).
However i’m more leaning towards reducing some of the Hz of the Luna’s.
@ppoirier ,
@DonLakeFlyer
@rmackay9
there is still one issue.
The directions (mounting place ) in Mission-planner and Qground-control aren’t the same !. This can have huge consequences on where the drone wants to avoid the collision ?!.
Just to make sure…
All the Luna’s have unique addresses from ALL other I2C devices on the same bus. Including non-Luna devices, right?
Hello Oeble, so the problem of bad connection is solved? What was the main reason of this issue?
Hi ,
Yes in m case yes. No conflicts with Pixhawk 4 GPS/Compass and ext. Pixhawk LEDs. all works .
This is including the luna’s all on I2C Bus.
Hi Ibrahimqazi,
i’m not sure why , but my Telem 1 & 2 ports act different . I,m not an expert on the Pixhawk board internals and could not find on the internet why they act different . The only this i see is This,
But it does not ring a Bell
got it thank you for the information
@ppoirier
So New/Old issue again.
After connecting the TF-Luna’s and the switch the sik 915Mhz to Telem 2 the lunas work fine.
Since i now have to use Telem 1 for minimosd , i noticed that the slow speed is still there on Telem 1.
This means telem 1 cannot be used , Telem 1 updates values/data every 3 or 5 minutes.
The strange thing is that changing settings ( the SR ones ) does not make a difference.
Question ,
1-what is the exact difference between Ports Telem 1 & 2 ?.
I have seen that Telem 1 does only 400 bps on 4 Lidars.
Telem 2 does 2000 bps .
2- How to change these settings ?.
Regards O.
I would suggest you go on dev channel on discord and explain issue with a log file ready to upload
Yes ,
Seems to be a bug ?.
4 luna’s on Telem 1 = 400bps on 2 Hz.
(would be 2000 on 10 Hz )
Thats (2000) what Telem 2 does now , even when bringing the Hz down . Seems to be not working.
At least i know the difference now between 1 & 2.
The 2000 is way to much.
PS where and how to raise this issue ?
To end this discussion ,
what worked for me at the end.
As The developers don’t seem to care that much , I got my drone working by doing this.
0-To get my Mavlink 915/433 sik radio working i moved it from Telem 1 to Telem 2.
1-To get fast working telemetry on goggles and VTX i moved my OSD telemetry from Telem-1 to Serial 4. (Telem-1 cannot be used somehow )
2-To give devices time to boot i changed BRD_BOOT_DELAY,0 to 20ms
3-To reduce the (4) Luna’s data load i have two new compiled arducopter firmwares with the lunas on 10Hz and on 25Hz /Luna.(to decide which one to run later )… ! the ardupilot driver resets luna’s every boot ! .
4-Also took out a failure in the TF-Mini I2C -driver @ the same time.
this line-----------const uint8_t CMD_SYSTEM_RESET[] = { 0x5A, 0x04, 0x04, 0x62 }; is wrong(=Trigger detection)
Should be — const uint8_t CMD_SYSTEM_RESET[] = { 0x5A, 0x04, 0x02, 0x60 }; (=system reset )
I hope this help some of you.
