Let come back to that one…
Setup your xwindows server to accept new clients. I think you have done that before?
Then ./Tools/autotest/sim_vehicle.py -v Copter --console -D --speedup 1 --map
Okay I did this by running
cp ~/.bashrc ~/bashrc_backup_2021_11_Dec
In both /mnt/c/Users/DELL
and,
I then removed the line that you mentioned, save the file and closed it.
For this I followed
To run this I did this,
It’s compiling right now. You were right, it’s much faster than running in the windows directory.
ok try adding the LIBGL_ALWAYS_INDIRECT
in ~/.bashrc`
export DISPLAY=$(awk '/nameserver / {print $2; exit}' /etc/resolv.conf 2>/dev/null):0
export LIBGL_ALWAYS_INDIRECT=1
I’ve had one person tell me that was necessary for their setup before
Okay I added this. Looks like this now.
Ran ./Tools/autotest/sim_vehicle.py -v Copter --console -D --speedup 1 --map
Again, some output
ok I’ve heard a person once needed to use this instead,
export DISPLAY=127.0.0.1:0
This is on wsl2 right?
In a powershell, do this wsl --list --verbose
Wait dont do that I this is an issue
Lets just get on Discord and Screenshare?
Sure, which channel ?
OK after trying many things and fixing a few issues here and there…
The main DISPLAY issue that was not on the Wiki is that you need to “Allow Connections” in “Windows Defender Firewall with Advanced Security” for the XWindows program, VcXsr windows xserver
This is under the Inbound Rules
and needs to be allowed for both Private & Public
network types
