New Fixed Wing AUTOLAND mode
The AUTOLAND mode here refers to landing at the home point (or a rally point). Is it possible to set such a rally point during the flight at which an automatic landing then takes place?
An example would be if the battery capacity runs out during the flight and you want to land for safety’s sake. But not somewhere without control, but at a suitable location that has been flown over beforehand and marked via a rally point.
New Improvements merged into master:
  1. Can be used after taking off in all pilot throttle modes (FBWA,MANUAL,ACRO, etc) as well as autotakeoffs
  2. Base leg replaced with a loiter to alt (especially useful if above AUTOLAND_WP_ALT when arriving)
    3.New AUTOLAND_OPTIONS param that has option to set landing direction upon arm if plane is using a compass rather than using initial ground course upon takeoff. More options planned in the future, eg options for climb before turn option mode entry in case a FS happens during takeoff or when flying low
Using rally points dont really make sense:
  1. if you can plan a rally point, then you can setup multiple DO_LAND_STARTS landing at those locations, no need for AUTOLAND which is primarily intended for protection at unplanned locations.
  2. each rally point could need its own approach setup params or approach direction…again, preplanning is required whereas now you just setup a generic approach once and if hazardous for the params at a particular new location, don’t use AUTOLAND or, better yet, use the arm option to set approach direction if you have a compass being used.
How did I miss this? I can really use it! Can’t wait to set it up and try it out.
Thanks for creating it …
Terrain following in the mode is now supported and a new minimum climb before turn on entry feature…docs soon
Been having fun playing with this - very nice. Curious if we’ll see this show up as an “RCx_OPTION” in the future?
If I get one more user requesting it, I will code it
I’m also interested by having autoland mode actionable with RCx_OPTION :slight_smile:
Would it also be possible to have the landing final approach based on wind direction instead of being fixed by an angle? I mean, as AP is knowing the wind direction at any time, it would be interesting to use it automatically as the opposite direction of landing and calculate approach based on it. Of course it assume landing in an open field as you can’t know by advance the wind direction at the time of landing.
Thanks a lot for what you already did.
I have PRs submitted to:
-add as an aux function
-add as a fence breach action
-add as a battery failsafe (minimum climb get disabled on batt failsafe)
Sounds great! I’ll definitely check this out when it shows in latest. Thanks for coding this up. It’s dead of winter where I’m at but come spring I plan of using this on my AeroScout.
Runway selection requires knowing where both ends of the runway are unless you accept midfield landings and takeoffs. IIRC there is a Lua script for runway selection.
Using AP wind estimate is not viable in my opinion…wind direction at ground level is frequently not the same as that when cruising at 1-200ft…wind direction routinely changes with altitude…and AP wind estimates are not made until turns are made, so using it on a takeoff failsafe is not practical…and landing direction is not “fixed by an angle” (unless using the arming capture compass based option), its based on your actual takeoff direction over ground…that may not be directly into the wind, but it should align with the runway, if not, which is what you want…
You are right and it is not as simple as I (badly) explained it. In general, I find AP very good in wind estimation and the way it takes it into account for automatic landing (I have sometimes seen it land my plane in extreme wind conditions in a way that I could not have matched). This is why I find it a shame not to take it into account to manage the choice of a landing approach. Of course this would only be valid for certain types of landings such as landing on an open field. This could also be the case for the choice among several predefined approaches. For example, in the case of a runway, AP could automatically choose the best landing direction thanks to two predefined approaches according to a direction as opposite as possible to the wind. Finally it could be a choice in case of failsafe to limit the landing length by landing facing the wind.
I know that development is a long and difficult task, so I thank you for everything you are already doing. Therefore, if this request is too complicated or long to implement, or if you just find it inappropriate please ignore it.
Thanks
AFAIK it is out of scope for autoland. IIRC there is a script for landing runway selection.
So newbie here,
I’ve had his results landing with 4.7 baro and GPS only. Lidar coming next week.
I’ve got crow braking set up. A glide no flaps is zero throttle at 7 percent glide. Full flaps in from the loiter is 30% throttle.
Question, should I manually activate flaps and crow on final, or will the auto flaps also activate crow and be a better option.
Seems that setting speed low enough to activate flaps is only available in pre-flare.
Volentex 2000, powered glider.
Cheers,
And thx for the amazing FW!
I’m relatively new to Ardupilot but I’ve successfully tested this mode with a foamy glider fitted with an airspeed sensor. It’s a remarkable piece of work !
Does the flight controller have a precise idea of the wind direction ? If so, and if the wind has changed direction enough by the time you activate AUTOLAND mode compared with take-off, would it be possible to land automatically in the opposite direction ?
even without an airspeed sensor, AP calculates wind speed and direction, although not as accurately and not without recent commanded turns needed to calculate correctly…it would be possible to invert the landing sequence if the wind direction has changed during a flight however that would be very dangerous in many situations due to obstacles, etc. so I would be against it in the code, even if as a user selected option, due to safety…however, if you wanted you could take the autolanding lua script I did , which I evolved the firmware version from (its a little different but works) and modify it
Thank you for your answer, which makes sense. I don’t yet have the knowledge to manage scripts, I’m going to work on it but I already know that my FC is too limited to run them
Do you mind if I try porting some of the logic behind the 4.7 mode to the Lua counterpart in 4.6 branch?
no, I dont mind at all…
