I just wanted to say that I compiled with my hwdef and it works great with my caddx Vista on the newest firmware (50mbps). Can’t wait for it to be integrated into master
about 1MB boards - Im using it on matekf405 ctr, 405-wing and Im going to use it on v6 nano with zohd drift, so yes, from my point of view we need msp on these boards any ETA when it will be merged to the master ?
Hello everyone, noob question here and i appreciate your help. I setup correctly my first arduplane based wing, and i am trying to setup MSP to get OSD/telemetry on my DJI Digital FPV goggles. I am using UART 6 on holybro kakute F4 v2 (Serial 1), so i setup serial1_protocl = 30 and serial1_baud = 115. I have also setup MSP_options to 1. I wired DJI air unit TX to uart 6 RX and RX to uart6 TX. I still cannot see any osd in my goggles. Am i missing any step here ? Thanks
Hi Jean, you’re the first one to report problems with GSPD, unfortunately I no longer have a test unit so I can’t even try to reproduce your issues
As for lat/lon position I remember that not all positions could be used and as soon as you moved to the right they would disappear, it’s a dji issue for I did the very same test with betaflight.
There’s a more recent version which does not add any features but it’s integrated with ardupilot OSD, OSD positions can be adjusted using mission planner OSD editor, it’s the version being reviewed by the dev team for inclusion in master, the branch is here configuration is quite different, you need to enable built in OSD and configure widgets on screen 1 using ardupilot standard OSD items, serial protocol is 33 and OSD_TYPE must be set to 3 Edit: for boards that do not have built in OSD you need to add “define OSD_ENABLED 1” at the end of the board hwdef file in /libraries/AP_HAL_Chibios/hwdef/
Thank you so much for all your incredible work on this. It is a tremendous benefit to have a first class OSD on my DJI FPV headset.
I wanted to let you know that build 0.9 is not working on my F765-WING. No data appears on the DJI headset and I don’t see the MSP parameters listed in Mission Planner.
I’ve now merged MSP support into master. New builds should appear on firmware.ardupilot.org in a couple of hours.
Huge thanks to @yaapu for the amazing work he has done on this feature!
