congratulations john, your boat is very beautiful, can you share more information about your boat, construction process, or how did you calculate the torque needed for the servo?
Hey John,
Have you made any progress with tuning your boat recently? I hope all is well!
Nathan the throttle is still causing problems.
If I disconnect the throttle from the controller and set it manually as it takes off it works perfectly, but coming in is a bit scary if there isn’t any grass around to drive it into.
The other funny thing is even with the manual throttle if I increase the cruise or WPT speed to more than 3m/s it goes wild like the old days.
I have seen there is a 3.5 rover out but I am too scared to use it as I’m running a new boat and a bit scared to be the first to test it.
A little bit of thread necromancy, but if it works well with manual throttle, just re-map your RC controller throttle to another output channel so you can control the throttle manually through the whole mission.
