To install future lib you generally just type
Sudo pip3 install future
@ppoirier I wrote about trouble getting future library on the JeVois, there is no “pip install” AFAIK that can be used there.
If you dont have pip you can installt it using
Sudo apt install python3-pip
Edit: the image must be pretty recent with python3 as default , in that case just use pip
Which type of landing is better for quadplanes if I chage the necessary side of the firmware and construct some codes from ROS?
Vision or precision
