How to set hard Home-position of Antenna tracker when folloving vehicle in STILS (e.g. Arducopter)
See this. It is not your case since I wanted to use Mission Planner as tracker, but if you have a Pololu Maestro (and your AT has conventional servos) you can experiment if it moves with SITL using MP.
MP: PLAN, right click, option to place tracker (default Home).
See that for rover I need to locate the tracker above the rover, not knowing how.
