I’ve got it running again on Ubuntu 22.10 (for pi). So far, so good. (it’s no speed demon, but it seems functional)
Same issue as all my other linux installs lately, and that the Quick tab will display no values. I’ve connected over Sik Radio and USB. I’ll try UDP/wifi later when I’m up for it.
I’ve installed MP-1.3.76 on RPi4(Raspbian OS) with this: Dropbox - MissionPlanner-Raspi4-Installation-Guide_English_V2.pdf - Simplify your life
And i didn’t have problems with usb joystick connection and usb telemetry connection. But i have troubles with videostream. I solved the problem by streaming MJPEG via VLC (video from HDZero). However, the delays in the video are quite large. I am going to fix it.
I tried other versions of MP (stable, lastest and1.3.79) - they did not run at all on RPi4.
Maybe my advice will help someone.
due to a growing number of people reporting that Missionplanner does not work anymore on Raspberry i decided to pick up this 3 year old project again.
maybe also, and mainly, because i’m planning to build a GCS inside a pelicase.
anyway: after installing Raspberyy pi OS version 11 (Bullseye) and then installing Mono i could run Missionplanner 1.3.8 without any problems.
I’d say, stay tuned for version 3 of my guide.
I followed the remaining instructions and it looks like it tries to run, but never does anything. I just get an hourglass for maybe 30s. Maybe it’s something with Mono and how it’s configured.
It looks like some of the way Mono is installed had changed. Your old guide, and the guide I tried, didn’t work anymore. But your Mono-Project link, did work. First time too!
It’s somewhat slow on a RPi 3b, but it’s running! Just plugged in my SiK module over USB at 56kbaud, and connected immediately and got data!
Is there any way to make it full screen? I’m using a 7" display, not optimal, but could be better utilized without the taskbar and window border. Kiosk mode would be ideal, might play with some things.
Nice! Thank you for trying. That confirms what I thought, that the guide for installing mono needs to be updated. Also at the end where the guide says that you should deactivate openGL, that’s not needed/possible anymore.
Indeed it is a bit slow, even on a pi4. But it works and at least for my use case(slow boats) it’s absolutely ok. And there is also a new generation of raspberries coming up.
I’ll see when I can find some time to update the guide. It’s overdue really.
About the size: I know that you can change a lot of the screen sizes depending on your needs. Wether you need he Map, the parameters or the horizon. However I think it would be best to ask that in an appropriate thread/category.
Happy that it works though I really like when people report back that it works and the guide was useful.
Yeah, you’re welcome! I like trying things out and debugging to (that’s my job at work). The Pi 3b is somewhat slow, I was more or less trying to do what I can with some Rpi laying around. Going to try this, OpenHD and Rpanion. Might get a Pi4 or 5 to try out. I have a few sitting around gathering dust, one with a nice 7" LCD.
BTW, I did disable Open GL. It’s just not in the same place on the current raspbi-config. Under Advanced (option 6), A2 GL driver option, G1 legacy, disable.
I figured ask you about the screen, play with it some, and post if I can’t get it working better.
So for your guide, basically:
Install the latest Raspbian, get SSH and VNC working like you outlined.
Install Mono using the guide here:Download - Stable | Mono
Follow the rest of the guide (install Festival, disable open GL, download Mission planner, etc.)
After three years, and quite some stuff that changed with MissionPlanner and even more so inside the RaspberryOS, it is time to update the Guide on how to install MissionPlanner on a Raspberry Pi (4).
there were reports, that it didn’t work anymore or people had problems following the guide and making it work.
it turned out, that quite a lot has changed inside the newer Raspberry OS, which actually makes it easier for us to install MissionPlanner.
as always there are some Pro’s and Con’s however.
on the Plus side:
You don’t have to use an 32Bit OS anymore just for mono to work
we do not have to deactivate OpenGL anymore
The Raspberry Pi imager software makes Flashing a SD card very easy
on the other side:
we can not use the official Mono framework for Raspbian because it still doesn’t seem to like 64 bit. so we have to use the debian version here, which seems to work.
i also had to use the (now outdated) raspberry OS “Bullseye”. because we know that it works stable on this OS and we still can use realVNC viewer.
Because: with the raspberry pi 5 around the corner, we can also use the newest Raspberry Pi OS “Bookworm” which, at the moment (until early 2024 probably), does not support realVNC viewer.
The 2 work arounds would be: disabling encryption (security risk) or using TigerVNC(not as easy as realVNC). This is only important if you need VNC anyway. But for a stable guide, OS “Bookworm” is not yet the way to go.
hence why i am looking for people that already have a Raspberry Pi 5 and are willing to test / provide info. I’m not sure yet whether Mono works with Bookworm or not. So the future will be exciting.
this leaves me only to say: thanks for the kind words, help and the over 2500 Downloads in the past 3 years. That does fill me with joy.
cheers.
edit: quick update on the raspberry pi3B: if you install the 32bit version of Bullseye and then follow the mono Guide on: Mono for Raspbian 32Bit then it should work just fine with a Raspberry Pi 3B. (thanks to @frodus17 )
Edit: if some moderator could add the new link also to my main post, that would be much appreciated.
