Why do not you use an hc-12 instead?
and serial and has an acceptable speed and reach
Because you need a receiver, wifi can get connected to a laptop or smartphone without extra hardware, or to 10 phones at a time.
or use a translator or it will be complicated through WiFi
Does MAVESP8266 work well with ESP07s?
Yes, works fine with esp07/12
My intention is to use an ESP8266 module to which I have loaded the latest firmware (firmware-esp12e.bin) which works perfectly and I can connect to the module and configure them, even there.
My problem is that I want to put it in STATION mode so that it connects to the Wifi module of the Dragonlink V3. I have tried several configurations, but I have no idea about networks and I canât connect.
This is the DL Wi-Fi configuration in TCP mode:
WiFi Setup:
The module ID is " DragonLink "
The Wifi Password is " DragonLink "
MISSION PLANNER CONNECTION INFORMATION:
Choose TCP connection with a baud rate of 115,200
Ip address to use: 1.1.1.1
Port to use: 1
This is the my ESP8266 Wi-Fi configuration
WiFi Mode: Station
AP SSID: ArduPilot
AP Password (min len 8): ardupilot
WiFi Channel: 11
Station SSID: DragonLink
Station Password: DragonLink
Station IP: 1.1.1.1
Station Gateway: 0.0.0.0
Station Subnet: 0.0.0.0
Host Port: 1
Client Port: 1
Baudrate: 115200
Can you help me with the configuration?
a greeting
Ive never used the devices you have, but two devices cant both have the same IP address.
Iâd suggest change one of them to 1.1.1.2
The subnets will need to be something like 255.255.255.0 for all devices.
Usually non-routable (private) devices have IP ranges like 10.x.x.x or 192.168.x.x
Any workaround to flash FC firmware using mavesp8266 directly over wifi ?
OTA flashing directly to the flight controller isnât really supported but if the esp8266 is on a serial port enabled by the bootloader (check the hwdef-bl.dat for your board) then it might work sometimes. Problem is that if you loose packets itâll fail and youâll need to retry / use USB. If you really need OTA firmware updates itâs best to use a companion computer.
Hello Eeveryone,
I followed the tutorial ESP8266 wifi telemetry â Copter documentation
I am using the adafruit board, connected directly without 3.3 converter or level-converter.
It works really good, until it doesnât. Sometimes its about 30 minutes and then it randomly disconnects.
Can anyone provide a solution for this PLEASE?
THanks!!!
Daniel
Is the recommended Baud Rate 921?
Yes, all of mine are configured that way.
Hello i am working on esp8266 wifi module. I was uploaded the mavesp8266 code for communication between drone and Ground control station and i was successful in connecting Flight controller with mission planner and QGroundController through UDP but suddenly it was disconnected from mission planner now am not able to connect to mission planner and QGC both. Anyone solve this issue.
