A guy named renatoa came up with some math for calculating flight times. I use it for all of my drones.
Here is his post on RCGroups:
" For any platform of any size and weight, the flight time is the result of:
time = whkg / (1000*R / eff_gw) * 60, where
whkg = battery energy density, in Watt hour / kg, ranging from about 150 for the high C packs to 270 for LiIons. 10C Multistars are 185.
R = ratio between AUW and battery weight
eff_gw = motor/prop efficiency, grams per Watt, taken from mfr data.
Be aware to get from table the efficiency for the intended thrust, and for 50% throttle !
Efficiency greatly depends on load, so don’t use efficiency stated for 1kg, to compute flight time of 2-3 lg platform !
Also, don’t use values for more than 60% throttle, the platform will be unstable, no more room for motors to do their control job…
As I wrote, this formula works for ANY size platform and energy source, lets do the math for some particular cases:
Case I Ph2
battery wh/kg = 5.2(Ah)11.1V/0.37(kg) = 156wh/kg
R ratio between AUW and battery = 1250/370 = 3.4
propulsion efficiency = 11g/W
time = 156 / (10003.4 / 11) * 60 = 30 min
Case 2 the 129 min record
battery wh/kg = 266Wh/kg - typical LiIon energy density
R ratio between AUW and battery = 3.4/2 = 1.7
propulsion efficiency = 14.1g/W
time = 266 / (1000*1.7 / 14.1) * 60 = 132 min
And finally, my 30 min case
battery wh/kg = 165, I use a Zippy Compact, having a bit more energy than the average LiPo
R ratio between AUW and battery = 0.75/0.195 = 3.8
propulsion efficiency = 11g/W - using Phantom 2 clone
time = 165 / (1000*3.8 / 11) * 60 = 28 min
As you can see from the above, reasonable precision of all estimations, proving this formula is valid for any configuration, so now you have a tool that should tell you what is wrong in your setup, and where to work to improve flight time.
The biggest unknown for most users is the propulsion efficiency, for this reason I think is mandatory to not buy stuff without manufacturer precise specification of this parameter."
I have attached a spread sheet that will do the math for you.
Calc.zip (9.2 KB)
