Attendee count (max): 21
Pre-Agenda:
- Welcome Gus!
- Welcome David Ardis
UTC1102 - https://github.com/ArduPilot/ardupilot/pull/12821
- Old PR from Chris
- Touched up a bit to do accel and decel
- Race condition between test code and the ArduCopter code
- The parameter is being dynamically updated by the code
- The test is setting the parameter but the code is changing it underneath
- Using parameters as temporary storage space
- E.g. WPNAV_SPEED
- Bill will change this to use a different variable
- Some sort of an accessor?
- Won’t be updating the parameter
- Would be nice to compact logic a bit
UTC1111 - https://github.com/ArduPilot/ardupilot/pull/12813
- No objections on the call.
- merged!
UTC1114 - https://github.com/ArduPilot/ardupilot/pull/12811
- Too strict on our error checking
- Need a better story around “recovery mode”
- Randy will merge after testing
UTC1118 - https://github.com/ArduPilot/ardupilot/issues/12805
- Maybe we should stream out “recovery mode” instead of “config error”
UTC1120 - https://github.com/ArduPilot/ardupilot/pull/12804
- Numerical or alphabetical?
- On the initialisation enumeration case statement
- Shows that whoever added the RC options couldn’t have tested them in SITL
UTC1121 - https://github.com/ArduPilot/ardupilot/pull/12775/files
- Tridge needs to look at this one
- Add a comment about the call to longitude_scale
- Bumped to next week
UTC1125 - https://github.com/ArduPilot/ardupilot/pull/12751
- Peter still working on it
- Devcall left on it and we’ll look at it next week
UTC1128 - https://github.com/ArduPilot/ardupilot/pull/12709
- Just documentation fix
- Question about lidarlitev1 - probably same driver
- Merged!
UTC1131 - https://github.com/ArduPilot/ardupilot/pull/12643
- Needs tridge
- Left devcall and moved on
UTC1133 - https://github.com/ArduPilot/ardupilot/pull/12631
- Merged!
UTC1134 - https://github.com/ArduPilot/ardupilot/pull/12576
- Needs tridge
- Sanity check was added
UTC1135 - https://github.com/ArduPilot/ardupilot/pull/12242
- Can be merged once the the zigzag stuff is removed
- Zigzag does its own stuff and doesn’t need the higher layer’s protection
UTC1140 - https://github.com/ArduPilot/ardupilot/pull/12108
- Ready for merge?
- SITL-only
- Needs RealFlight
- Discuss topic to be linked in
- Randy to review
UTC1143 - https://github.com/ArduPilot/ardupilot/pull/10830
Randy agrees new messages are OK
We can refine the algorithm once this is in
New messages coming
Randy will merge
UTC1149 - notch-filter tuning
- Amazing results?!
- Pushed P up a vast amount 60%
- Went back and forth
- Including attempting to run new tune with filter disabled
- Which didn’t go well
- Solo + this will be awesome
- The Wiki instructions were sufficient to do all this
- FFT analysis to determine where to put the filter
- About 200Hz on Solo
- Frame resonance @90Hz
- So static at frame resonance
- And new dynamic harmonic notch filter at 200Hz
- As throttle goes up and down the harmonic notch filter notches out that noise
- [10:52 AM] (Channel) Peter_Hall: https://discuss.ardupilot.org/t/tuning-the-harmonic-notch/48836/34?u=iampete
- [10:52 AM] (Channel) Peter_Hall: http://ardupilot.org/copter/docs/common-imu-notch-filtering.html
- [10:53 AM] (Channel) MikeBoland: How did you increase the PID’s?
- 300 or 400 of noise to 12?!
- Mat acknowledges he has a tendency to see and hear what he wants to see
- so he was somewhat rigorous with his testing here
- Even on stock Solo there’s a significant change
- This code doesn’t go into EKF
- But Leonard said the control is more stable that there’s less garbage on the accelerometers which are going into the EKF
- Less jitter
- PR in place to update the frame parameter to enable the notch filter
- New PID values for green cube
- Frame resonance with/without gimbal?
- Matt will experiment
- The worse your Copter is the better this feature is
- Even perfect Copters will
- Andy is working on some more magic filter
- To eliminate the manual steps
- Dynamic FFT to work out where the issues are
- If you have a Copter and you have vibe issues
- You need to play with this
UTC0004 - https://github.com/ArduPilot/ardupilot/issues/12547
- Beta testing continues on both Rover and Copter
https://github.com/ArduPilot/ardupilot/issues/12509
- RC option issue
- Otherwise in pretty good shape
- Oneshot not working?
- Blheli telemetry issue resolved
- Dual-gps for yaw needs help
- Copter
- Lots of users
- Lots of reports to investigate each day
- Navio2 leds not working
- D-shot?
- iBus not working for some users?
- Cal not working?
- GPS blending not working?
- Parameter downloads slow when CAN enabled?!
- User gives a brisk scenario on how to reproduce
- Getting stuck on takeoff mission item when switching from loiter
- Probably in 3.6
- Probably some way off
- Help appreciated!
UTC0011 - Close
