Other than APM, all the rest of those have H743 processor variants.
It’s true my ‘bars’ were too small and current was about half real world hover current. I could print bigger ones but I will just replace the ESC.
This issue has set me back months and used up time that my wife says should have been spent decorating. I need to get this fixed and move on.
If the props fittings allow you can move the props around one position and flip them over
Just a thought outside the loop!
Is it the same TX in every crash?
Could the problem be within the transmitter, noisy Pots, or loose antenna, bad RF output?
We would see that in the logs
Good point! Just a thought as it seems to be the only common thing in all of the incidents.
Looking forward to the answer!
