Copter falls from sky after a couple minutes
@Yuri_Rage @dpapworth
One thing I want to point out about using a logical switch for arming: If the RC failsafe is caused by the radio powering down (RC Battery, etc), when the radio powers up again the logical switch will be 0 and will send a disarm command to the drone. Not a reason to not use this method, but just be aware of it. For critical configurations I use stick arming, with a motor stop switch, or on copter I’ve started to use the arm/emergency stop configuration.
I’m curious @Yuri_Rage why you decided to use the logical switches rather than just normal stick arming that’s already in Ardupilot?
Apologies if I was unclear - I don’t actually use the logical switch for arming. I use stick arming, but the logical switch follows the gesture and switches Ch5 (which is unassigned in the autopilot) such that ExpressLRS sees the flags set by it. Is that a little clearer?
Yup, that makes sense. Thanks!
I do sometimes monitor Ch5’s logical switch output in my LED scripts and either change the lighting effect or print a GCS message when it switches state. If I use the e-stop feature, it ends up on Ch5, and I forego the logical switch complexity.
Further discussion on arming philosophy should probably go in another topic - I’ve taken enough space here with the tangent :smiley:
I also use an arm switch in conjunction with the throttle, but as you say if the radio powers down/up the channels will be in their default (disarmed) state.
My theory is: if something strange happens to the radio, leave it OFF and let the aircraft do what it should, RTL. Once the aircraft is landed, mess around with the radio all you like.
I also have a “throttle cut” switch set up like a lot of the old Plane transmitters had, so if there is something odd going on we can just hit that switch and the copter goes into RC failsafe - also RTL.
The old throttle cut switch seemed like a good idea to run with even on the new transmitters, since you can leave it in CUT and the radio or the copter wont ever do anything, by accident or otherwise.
Your throttle cut switch would also work nicely on Ch5 in an ELRS config (though I understand it’s possible to have it just override TX throttle and not be assigned an output at all). It’s a technique I hadn’t thought about but is the most logical take I think I’ve heard yet.
I agree. 100%. As long as people understand what can happen with these configurations then it’s safer to play and tinker with all these tools.
So I changed to some 8" 2 blade props.
Same power loss/disarm/total power failure ~1.5 min in.
New Crash Log Link
At least the 2 blade props are way more resilient than the 3.
Any new ideas folks?
sigh
Just old ideas. Use the right combination of components. Nobody had 7" props in stock?
If you want to try for another crash reset the Initial Tune Parameters for 8" props and set these parameters:
ATC_RAT_PIT_D,0.002 (and same for Roll)
ATC_RAT_PIT_I,0.08 (and same for Roll)
ATC_RAT_PIT_P,0.08 (and same for Roll)
PSC_ACCZ_I,0.2
PSC_ACCZ_P,0.1
So you know what to look for in the log here are the motor outputs oscillating and then 2 lose thrust and crashola.
I do hear you Dave, but the thing flew for almost 8 minutes, w/10", with the last set of parms you folks gave me.
I had the 8" ones around, and figured 8 is better than ten. I will order some 7" though.
That last two seconds you show there is dramatic!
Any guess on where is that failure coming from? The ESCs overloading?
In my little mind the stupid thing should stay in the air longer with smaller props.
Sorry to keep wasting your time.
Xaidin
What was hot after the crash?
Besides all the good info… I use 960KV for 8,9,10 props single or tri blade. Also check the screws to make sure you not dented the motor coper.
Update:
Changed ESC fixed issue.
After getting it flying awesome, DKEMXR is right, it’s super under powered. =)
I have a question while reading this. What would happen if you have a channel configured to 165 ‘Arm / Emergncy motor Stop’ and you accidentally trigger it stopping the motors mid air. Will it be able to stabilize itself in any position if switch is triggered again( upside down for instance) while in loiter or AltHold mode.
Yes, theoretically if there is enough altitude the copter can restart motors and stabilise itself if it was Emergency Motor Stopped and you reverse the switch.
It’s not like Arm/Disarm where there’s a procedure to run through - all the control loops and all is still running.
Even if the copter is in AltHold or Loiter Mode, Will it be able to stable itself even if it is upside down.
Not sure of the official answer, but I had one get upside down on me in Loiter (being stupid) one time. It came down really hard on it’s back/battery. Didn’t auto flip back over for sure.
It’s amazing how tough drones are, it fell from -really- high up. Only broke like 5 parts.
I imagine you could flip it in Acro mode, but I’m a crappy pilot, so just fly around in Loiter.
I tested it after discussion with @xfacta . I tested a 7” FPV like this. I conducted two types of experiments. In first case, it was stationery while in the second case, the copter was moving at 15m/s. In both the cases when I restarted the motors, the copter was able to get itself stable. The mode was AltHold and in one case the copter flipped and was able to recover itself from about 180 degrees (upside down).
But the bad news is after doing it a few times, it crashed from about 100m. The SD card got damaged in the crash so I couldn’t analyse the logs but based on the visual observation. I assume It got into ESC desync or one of the motors malfunctioned.
